1 - 12 of 12 Posts
Frey
While riding in a benefit yesterday I was running at 55mph at about 5k RPM and the bike started to loss power then the tac went to 8k and bounced around then all electrics went out and I had to coast to a stop. After I sit for a min the lights come back on and she starts runs for a mile or two and cuts off again. It will then run fine for about 50 to 60 miles. what could be causing this? Also is there any kind of kill switch in the tank that can come loss and cause a buzzing sound and if so could this be the issue?
OK, 55mph at 5K rpm you must be running in 4th gear because 5k rpm in 5th = about 72 mph.
I can`t help much with diagnosing the electric gremlins, except to note that the tach reads off the front ignition coil.
Not sure why it would jump to 8K rpm when you are losing power though.
The buzzing in the tank sounds like it could be POOGS.
http://www.vn750.com/forum/showthread.php?t=17572
Crap, I WAS in 5th gear.
Could be an internal intermittent short-circuit in the battery, but this isn't really supposed to happen with an AGM battery. I had a very similar probem, but with a flooded-cell. How old is your battery? Perhaps you could have the battery tested- this would be a good starting point instead of willy-nilly trying to find a shorted wire or troubleshooting the kill switch next to the throttle.
Any updates Frey?
I had my tach bouncing once and it ended up being my battery cable came loose. Check all you connections.
Recently replaced my Ignition assy. I had a similar problem. Next time it happens, try to slightly turn the key to the left and right, and see if the bike comes back to life. If not, take note if you were in a turn, as there are MANY wires in that area that can chafe and then short out, causing loads of electrical problems. Be prepared for quite the time untangling the rats nest there.:beerchug:
Frey
Discussion Starter #6
Update:
No to POOGS ( I did however use a piece of pantyhose to make a cover) as for the question of the battery I have not had it checked I did kill the battery about a month ago and charged it on my home charger. So a flooded cell or even a dry cell could be the trouble maker. All connections have been checked and as for position of the bike during the cut off it is on the straights when it cuts off. Now to let you know it has not happened since the Saturday ride.
Any updates Frey?
Second that - my negative post came off, had the same "high rev tach" phenomenon. When the cable came completely off, I finally found it and screwed it back in. No prob since...
Member? ... check.
If I am reading this right, you lost both ignition and lights when this occurred. The ignition and lights are powered through seperate contacts in the ignition switch. This makes me consider a common point upstream of the ignition switch. I would clean/check/grease the connector on the wire leading from the (+) terminal of the battery to the JB; white with read stripe? I would probably replace the 30 amp fuse for good measure (is the fuse socket clean?). I would also check the white wire leading from the JB to the ignition switch. If you put a continuity (or light bulb) tester on the white wire from the JB to the ignition switch, then pull, twist, and mash on the harness throughout the length of the harness, you might find an area where the continuity fails.
Intermittent problems are difficult to find, and can at the worst leave you stranded. I would carry enough 14 guage wire to go from the battery to the ignition switch for a while. I would also have a plan to be able to easily install it beside the road. I carry a jumper to ground pin 12 of my JB if I have starting issues on a ride. Grounding pin 12 of the JB bypasses the kickstand, clutch, transmission safety switches.
Of course, this is after you have cleaned and tightened the battery connections :).
my2cents.
Frey
Discussion Starter #9
Would a failing stator be the issue? I am going to tear apart the wiring harness today and look for a short but after it happened again last night right after start up I put it on a charger and it fired right up after about 2 hrs on the charger. So I am not thinking it is a short.
Have you cleaned and lubed the ignition switch. It is not to hard of a job. Just make sure that you have some thing to catch the ball and springs that may fly out.
Member? ... check.
When it failed, what checks did you make? Did you try the jumper wire I suggested in post#8?
Frey
Discussion Starter #12
We started to tear down the bike today and found that the right front plug was WAY loose have not had the issue so let's hope this was the main issue.
1 - 12 of 12 Posts
