1 - 4 of 4 Posts
Does anyone know where to route the vac hose from the air valve. I only know of 5 nipples on the carbs. Two fuel, the two that go to the right ear, and the hose that goes to the pet-cock. And what is, coastering?
The Professor
Coastering is removing the air valve, hoses and puting a cover plate on the cylinder head. The air switch vac hose connects the rear carb vac port. :beerchug:
I can't find another port,lol. Although you really can't see very much around the carbs. Which side of the bike would I look on. And is it near anything noticable? Thanks for your help.
The Professor
It's on the right carb, the port is in the same place as on the left carb. The PO probably removed the vac line and capped the carb port.
1 - 4 of 4 Posts
