1 - 9 of 9 Posts
What have you tried so far? Does the engine turn over? Have you checked the spark plugs, fuel petcock open, ignition on, kill switch set to run, etc?
engine turns over
i did check the outer part of the spark plugs it might be a good idea now that i think of it to take them out and check
fuel petcock is open
ignition is on
kill switch is set to run
Can you please describe what is happening in more detail. Does it stumble but not start, or just crank and crank?
My VN had really old spark plugs when I bought it, and would barely start after lots of trying. After swapping them to new NGK iridiums it started no problem @ all.
You can test them before you swap them out by pulling one at a time, connecting the wire, and holding the threads up against the engine block while you hit the starter... if you get a nice fat spark, they're good...
alright i swapped the spark plugs and petcock now it starts fine thank you
Glad we could solve your problem....
Now we would like pics of your ride...pls accommodate us !
We love pics !
tia
:smiley_th
1 - 9 of 9 Posts
