One more thing to add, if you have never flushed your brake fluid, it is old and needs to be done. Should be done about every two years I think. It's really easy to do. Bike on centerstand, put a tube onto the zerk fitting on the right front caliper and put the other end of the tube in a glass jar. Put a towel over your tank so you don't splatter any juice on it. Take the master cyl (MC) cover off. Make sure your level is full in the MC and gently squeeze the brake lever and hold it. While holding the lever, open the zerk fitting with a small wrench and let the pressure off, then close it, all while holding the brake lever in. Slowly release the brake lever. Then check your level in the MC and repeat. You do this over and over using new Dot 4 brake fluid until you see the clean fluid coming out the drain hose you put on the zerk fitting. Flush it a couple more times and then move to the Left side and repeat. You might need a hand to do the left side. Caution! Don't let the fluid level get too low in the MC or you will suck air into the brake lines! It's tempting to do this three or four times before adding fluid but you mess up and you'll wish you didn't! (it can be bled out, but just don't get yourself in this situation!) Anyhow, that's my story. Good luck!
