billhig said:
Is the ring and the lever one piece or two pieces? ronayers shows one straight piece. My ring has a broken piece that looks like where the lever attaches. I'm trying to find out if I get the lever will it include the ring?
Bill...it should be one piece. It looks to be p/n 46092-1124 in my TechManualCD, called the 'lever-grip, choke'. I had this assembly off recently when I changed out my handlebars, and it's one piece, I'm sure. The base of the lever is an O-ring that goes around the handlebar. It has a slot for the choke cable barrel, and the whole thing fits in a track inside the switch housing....
When you get your replacement, you may have an easier time installing if you remove the bars...this will give you more slack in the cable....
