1 - 11 of 11 Posts
So, been having trouble finding a part number for the VN750 85 front brake switch. The dealer gave me a replacement, but it doesn't fit. I have been looking at the parts fiche to try to get the correct part number but can't find the part. The problem is that the 750 didn't exist in the US in 85, and all the online parts fiches seem to be US based. I can't even get an accurate description of the bike on any online vin decoders, because of the same issue. Can anyone point me in the right direction on how to get a part number for this part? Would appreciate any assistance.
Thanks
Don
Thanks Don
The throttle grip was changed along with the Rectangular/Round Master Cylinder....brake levers are not inter- changeable either.
The Change happened ( iirc) 1990.
So, 1986-1990 would all have the same replacement part #.
Look up 1986 or 1987...you should be fine.
hth
:smiley_th
Thanks for the reply. If I look up the part number I was given, 27010-1056 it comes up as :
"1986 VULCAN 750 (VN750-A2) - Front Master Cylinder"
But, this switch is not the same shape/orientation as the one on this bike and definitely will not fit.
Btw, I have a round master on this bike.
Don
Discussion Starter #4
Just went through the parts I have for an 86 and the switch I have is definitely not the same. The 86 mounts facing forward but the one I need mounts on the bottom.
Don
Discussion Starter #6
Well, what a saga. The dealership now suggests that someone has changed this. They of course are full of it. I even mentioned that this bike has the round master and they swear that the fiche shows it should be rectangular. i hate dealerships! Anyones, I found one on ebay that has a picture and is identical, but it's not cheap. 14 bucks plus more than 20 bucks to ship something that weighs like 2 grams. This is snowballing into a major pain in the a$$.
Don
Discussion Starter #7
I do have the master from the 86 parts. But, it seems ridiculous to me to have to change the master just to replace a simple switch.
Any hydraulic 7/8" master cylinder will fit, where is your RH mirror?
this time i am going to have to side with the dealer your bike should have the rectangle mc
if you have the round one then yes some one changed it to the newer version
thats not a big deal though just order the switch from 91 or newer vn750 and it will work
x2 ....that's an absolute ! ....problems solved !
Order from 2001 or newer Parts listing !
Glad we were able to assist you in your situation .
:smiley_th
Discussion Starter #10
Actually I figured that out :). Just came from the dealer and got the correct switch. Should be good to go now.
Thanks
Don
1 - 11 of 11 Posts
