1 - 20 of 26 Posts
Discussion Starter · #1 ·
does anyone know a site which shows the history of the 750 vulcan and changes thru the years??
Don't know of one, but with as few changes as these bikes have had in 20 years there would'nt be much to report on.
Thanks to 750 forum...
Changes in the VN750 over the years
If you have additions or corrections to this document:
- Contact: [email protected]
or
- a forum moderator
New Cost:
$5,500 (1985)
$5,500 (1987)
$5,500 (1988)
$_,___ (19__)
$6,090 (1995)
$6,090 (1997)
$6,090 (1999)
$6,190 (2000)
$6,190 (2002)
$_,___ (20__)
Air adjustable forks
- '85-'88 = only years
Brake master cylinder
- '85-'90 = rectangular
- '91-'06 = round
Brake Lever
- '85-'90 = same (dog leg shape as per OlHossCanada)
- '91-'06 = changed (flat throughout length--OHC)
Clutch lever is the same for all years
Engine color
- '85 only = black
- '86- up = natural aluminum
Engine displacement
- '85 only = 699cc
- '86- up = 749cc
Fuel Cap latching
- '85-'87 = close without key
- '88- up = need key to close ????
Fuel Control Valve
- '85-'__ = RES - ON - PRI (Prime)
- '__-'__ = RES - ON - OFF
Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99- up = none ????
Grab rails, Sissy bar, Passenger footpeg mounts
- '85-'86 = aluminum
- '87- up = chrome
Instrument bezels
-'85-'__ = aluminum
-'03-'up = chrome
Mirrors
- '__-'__ = rectangular
- '__-'__ = round (at least until 1991 as per OHC))
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95 up = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95 up = 13270-1170 = 2.76" (70mm)
Shock absorber
- '85-'98 = 45014-1304
- '99- up = 45014-1710 older ProTac brackets may interfer with air valve
reported by Jim "Pick" Foster
Side covers
- '85-'86 = Ebony
- '87-'98 = Chrome
- '99-'00 = Gray
- '01 only = Bronze
- '02 only = Black
- '03 only = Red
- '04 only = Ebony
- '05 ____ = _____
- '06 ____ = _____
Wheels
- '85-'86 = painted black
- '87-'up = natural
Wiring harness
- '85-'88 have a Turn Signal Control unit
- '89- up Turn Signal Control unit eliminated.
- '85-'88 are NOT interchangeable with 1989 and up
Won't work by leaving the signal circuit open
__________
- '__-'__ =
- '__-'__ =
__________
- '__-'__ =
- '__-'__ =
Paint color listing:
http://f1.grp.yahoofs.com/v1/MKNSQ_...ImuqSr1GH9sg2oU-Ao6Z48vwhC05bJ-D08M/color.xls
A # Year Tank colors Side cover
A 1 1985 _______ / _____ Ebony _____-____ & ____
A 2 1986 Black / Red L.V. Red 36002-5183-P5 & 5184-P5
A 2 86 Black / White Ebony 36002-5181-H8 & 5182-H8
A 3 1987 Black / Gray Chrome 36001-1359 & 1360
A 4 1988 Ebony / Gray " " " "
A 5 1989 Ebony " " " "
A 6 1990 Maroon / Black " " " "
A 7 1991 Maroon / Black " " " "
A 8 1992 Blue / Blue " " " "
A 8 92 Green / Green " " " "
A 9 1993 Blue / Gray " " " "
A 9 93 Green / Green " " " "
A10 1994 Green / Blue " " " "
A10 94 Red / Red " " " "
A11 1995 Green / Blue " " " "
A11 95 Red / Red " " " "
A12 1996 Red / Gray " " " "
A12 96 Blue / Silver " " " "
A13 1997 Red / Gray " " " "
A13 97 Ebony / G. Silver " " " "
A14 1998 Bronze / Red " " " "
A15 1999 Ebony / Gray P.C. Gray Blue 36001-1284-VK & 1285-VK
A16 2000 Ebony / Gray P.C. Gray " " "
A17 2001 Graystone / Bronze M.D. Bronze 36001-1284-7R & 1285-7R
A18 2002 Black / Silver P.G. Black 36001-1284-86 & 1285-86
A19 2003 Red / Graystone L.V. Red 36001-1284-2T & 1285-2T
A20 2004 Ebony / Silver Ebony 36001-1284-H8 & 1285-H8
A21 2005 Ebony / Silver Ebony " " "
A22 2006 Ebony/ Persimmon Red _______ -
Gnarly Jokester
Thanks for the History as you know it.
Vulcan 750 Rocket Rider - - - - - - - - -
"Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99- up = none ????"
My '95 has one tube, wife's '93 has two...if that's a distinction worth noting
I think two vent tubes are on all later California gas tanks.
- '85-'87 = none
- '88-'98 = tubes
My '99 has one rear vent tube.
Here's a little Vulcan history with an offshoot model that existed for to production years early on. Kawasaki actually put out the ZN700A Vulcan LTD in 84' and '85 and it was the Vulcan body with a vertical air cooled four engine in it. I think that the 550 LTD started off as a KN designation, but someone else might could confirm that.
Thanks,
any one know if the '94-'95 A10 has a temp gauge or just a warning lght, and does it make a difference which sender unit is used?
I would think they'd have the temp gauge. As far as I know, all VN700/750's had them (atleast here in the States)
As for the sending unit, I haven't a clue. :confused:
Growling at the World...
Thanks,
I've heard of this bike. Have any pictures???
This one is in our gallery...
That is just a garden varity KZ700LTD. It was never called a Vulcan by Kawasaki.
But one thing that it can do is provide the parts if someone was willing to try a rear disk brake modification as the swing arm and rear wheel (on some models) are the same as the VN750. The only real problem would be trying to find a place to put the brake res... I've just never had the balls to try that drastic of a mod...
The VZ750 that I've heard of looks just like a Vulcan 750 that we all know and love but with minor differences to the rear seat rail (shorter) and a chrome front fender. From what I'm told is that it was available in Japan, Australia but not released in the US. It was, once again from what I was told, a V-twin but was the early production model made in Japan in the 80's. The history on this model is vauge at best...
Cheers hyper!!
Much appreciated!!!
Sorry Bulldog, but he said zn700. That's what I thought you were wanting a pic of. It is a nice looking ltd though. The pic you showed looks like our bikes for sure.
Even with that, there was still never a ZN700 Vulcan. The Vulcan name started with the 1985 VN700/750 model.
Interesting stuff on the ZN & VZ bikes.
I couldn't find any info on them anywhere. :hitanykey:confused:
Did you guys happen to notice the post about the ZN was from a year ago?
1 - 20 of 26 Posts
