1 - 2 of 2 Posts
This was an easy one: I just drilled a 5/8" hole in my turn signal brackets, then drilled and tapped a 1/4-20 screw hole normal to it. The 1/4" bolt holds the flag pole in place. I was thinking of maybe replacing the wooden pole with something stronger.....and maybe adding a wire to the flag so it doesn't wrap around the pole.
What have you all done as far as mounting a flag? :carryflag
Im curious to know since ..i would like to add something to my saddlebag supports someday..to run flag or flags.
1 - 2 of 2 Posts
