Made some more progress. Decided to hold off on rebuilding the front end until I have the bike running properly. I mounted the front end from the VN750 to the 454, then removed the wheel, brake lines etc to get stuff out of the way. Ive mounted the bars, choke cable, and Tachometer. I still need to install the throttle cables.
For now I just wanted to get the bike to where I can verify the wiring is good, the bike starts and runs well, and I can sync the carbs with it on the lift. I was having an issue where the starter button wasnt working, so last time we started it we jumped the solenoid.
After checking diagrams, connections etc I figured it must be one of the safeties. Checked the kickstand and brake switches.. finally realized it was the third safety at the clutch. I hadnt mounted the controls for that side and sure enough once I plugged it in the starter button started clicking the starter no problem.
Heres how she is sitting right now
I went ahead and scrubbed the airbox to get it nice and clean before installing. I actually ordered this from Europe, it just happened to be the best one available on Ebay at the time that had the filter housings and clips also. A nice little bonus is that I dont have to get a rubber plug for the hole from the emissions tubing because this model did not have emissions installed, so theres no hole in the airbox.
I ordered new oil filters and new air filters, and I received my new airbox in the mail.
Next on the list is to put fresh coolant in, new oil and filter, and install the air filters / airbox.
Once that is done, I will return to the front end. Plans for the front end look like this:
1) Swap triple trees. The VN750 and 454 Triple trees are compatible size wise, but I need to use
the 454 lower triple because the frame stops are different on the 750. The upper triple tree has a
crossthreaded fastener, but I may be able to tap it instead of replacing.
2) Disassemble forks. Send fork lowers and triple trees to shop for blasting and powdercoat.
3) Rebuild forks, replace seals, Steering Stem bearings, etc.
4) Reassemble front end.
