-   Carbs and Fuel System (https://www.vn750.com/forum/22-carbs-fuel-system/)
-   -   easy adjust thumb pilot screw (https://www.vn750.com/forum/22-carbs-fuel-system/98898-easy-adjust-thumb-pilot-screw.html)
JETHRO 11-08-2017 08:13 AM
Just bought a thumb screw pilot adjuster for the bike and does not seem to be long enough to pass the vacuum pipe coming out next to the screw hole, Has anybody else experienced the same problem and can it be solved ?
ubertalldude 11-09-2017 04:52 PM
only thing I could think would be to make the screw head smaller, which unfortunately defeats the purpose a bit. where did you get the screws from? I've been interested in those for a while now
JETHRO 11-10-2017 06:56 AM
Got them off ebay , A few people sell them but they need to be a bit longer to fit. Shame really, I could grind down thumb screw but these brass screws will be spoilt.
JETHRO 11-11-2017 03:55 AM
well I have sat and thought about it and I think if I grind knurled head of screw at 45 degrees I can get it to fit and still retain the shape as I only need to grind half of the screw head away, no good as it is anyway!.
Knifemaker 11-11-2017 09:06 AM
My only question is why you need "easy adjust" screws? I'd think that once you set them you'd never have to do it again...
Also a large (heavier) screw would be more apt to loosen do to vibration.
I would however like to have adjustable main jets :)
JETHRO 11-11-2017 09:23 AM
well I set my pilots to colour of spark plugs and I am always tweaking them, just me fiddling really.
DenverDiesel 01-27-2018 08:17 PM
Does the plug need to be at the end or is that just a tamper-prevention for emissions?
JETHRO 01-31-2018 05:48 AM
I removed tamper plug when I did ear shave ,these adjust screws are substitute idle items.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
