#1 possibility-have an opportunity to buy a 2009 650 ninja with bent forks and front rim,two brothers slip on,power commander, regeared sprockets for a little better acceleration, for $800(will take payments). with a couple different combinations of triple trees, a 636 ninja front end is almost a bolt on,which,with a better rear shock, make these bikes handle REALLY well(with $500-$800 invested)
#2
finish KeriAnn,a gs650.needs fab work for rear fender mount,a solo seat(and fab for mount),new master cylinder on front,either rewire harness under headlight, or buy new one, figure out why there is no spark,update both stator and rectifier, make battery tray and electrical box,might have to tune carbs(already rejetted but haven't started bike) for pods and four into one with supertrapp muffler (may get more disks for better breathing) and clean up and paint
#3
Melissa Fahye.needs stator, balancer bushings,tires,rear shocks changed,cleaned up and cables etc.etc
#4.
Priscilla dohc cb750.needs master cylinder and one front caliper, suspension put back to stock(just did it)rear brakes,valves adjusted, front tire changed,need new side plastics (optional),and tank repainted, possibly new sprockets (might raise a tooth in the rear)
#2
#3
#4.
