-   VN750 General Discussion (https://www.vn750.com/forum/11-vn750-general-discussion/)
-   -   Fuel gauge stopped working (https://www.vn750.com/forum/11-vn750-general-discussion/8235-fuel-gauge-stopped-working.html)
uffs 08-15-2008 02:55 PM
Hi All-
My fuel gauge stopped working, it always says the tank is full. Occasionally it will slowly move over to whatever level I'm actually at, but then almost immediately it will slowly go back to the full mark (or it will start to move to the left, then quickly move back to the right)..
I know this could be a few things (the cable from the tank to the gauge, or the level sensor itself), but was wondering if anyone knows of any known issues with the fuel gauge on the VN750..
Thanks!
rubyrick 08-15-2008 03:01 PM
Maybe you bike is blessed with a perpetually full tank of gas. So the gauge could be correct, and your gas is never used up. Boy, would that be nice, huh!
uffs 08-15-2008 03:11 PM
HA! Yeah, maybe I'll stop getting gas and see what happens.. :smiley_th
Sky Rider 08-15-2008 04:04 PM
No known issues with the fuel sensor.
It's not like the stator/RR, or the "coffee grinder" noise, or the ACCTS.
dragon159 08-15-2008 04:44 PM
Mine never worked from day 1 ... but mine always read empty. I was able to fix it by soldering together the broken connection inside the sending unit. My guess is yours is shorted somewhere or the float arm is stuck. Start by unplugging the sending unit at the back of the tank, if the guage goes to E then the problem is in the sending unit, if it doesn't move it's in the wiring or guage itself.
niterider 08-15-2008 06:04 PM
It is more likely the wire that comes from the sending unit. It may have a bare spot on the wire that sometimes grounds and keeps it from working right. When ever the wire is not grounding (shorting) to the frame it works just momentarily. Or the wire is somehow broken in two and sometimes it connects and the guage works for a bit.
JWenhart 08-15-2008 10:47 PM
Does our fuel gauge ever work? Mine reads full for about 100 miles, then goes to empty in 14.:D
niterider 08-15-2008 10:51 PM
Mine works rather close to what fuel I have in the tank.
Hiker 08-16-2008 07:02 AM
Fuel guage...
Surprisingly, so doe mine.
Old Dog 08-16-2008 09:10 AM
Mine reads full for about 50-55mi, then 1/2 tank at about 100-110mi, then lines up with the red empty mark at about 145-150mi. and is ready to start missing at any second and be put on reserve...
Rev. 8-17-08... Got 115 mi to exact 1/2 tank reading today, the best since I installed the 110 tire...
Have a good one ...Old Dog...
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
