Ok I am having extremely hard time cranking the bike and while trying to crank it is having a issue backfirinv. Most are soft but some are extremely loud. Where should I begin to look?
if it is not the battery check the ignition coils for proper voltage if it is not getting right at 12 volts on the red wire to the coil then you may have to do the ignition coil relay mod
if all that checks out and doesnt solve the problem i would start looking at the petcock
Ok it is probably the battery. I still have the Walmart battery that I bought two years ago. It cranks real slow but it will crank the bike. I bought a battery tender and that helped cranking it a little but tonight it tool a few minutes before it would crank. My wife thought I shot a gun when it backfired it was so loud.
I am unable to buy a battery right now due to finances so I guess I will have to stay with hard cranking.
When I get the AGM, where do y'all recommend?
I have done the coil mod already but there has always been a issue with poor spark to my plugs no matter what kind I use and this is using a car battery with 650 cranking amps. I think that there is the possibility that I need new coils and spark plug wires too. Can I still get these?
Also can the carbs being too rich cause slw starting?
You can make the plug wires yourself (using generic plug wire), or buy sets off ebay for $30. Get a multi-meter out and test the coils resistance before buying new ones. Follow the procedure in the manual.
Related Threads
Kawasaki VN750 Forum
411.9K posts
42.2K members
Since 2000
