-   Wheels, Suspension and Brakes (https://www.vn750.com/forum/27-wheels-suspension-brakes/)
-   -   front wheel noise (https://www.vn750.com/forum/27-wheels-suspension-brakes/57201-front-wheel-noise.html)
berzerker1982-BL 06-27-2014 12:24 PM
front wheel noise
Ok so heres the run down
2003 vn 750
New tires and new used speedo.unit on front
So i keep hearing a noise that i think might be a bearing noise coming from the front the noise is not constant and is was happining withe the old speedo unit withand without the cable on....makes same noise with new speedo unit as well.
There doesent seem to be any play in the front tire but sounds like a zipper noise...
I did notice that when puttingthe new speedo unit on that the brakes rub a little when wheel is spun. And this morning the noise was ciming and going but wheni was makingthe noise it seemed. When i leaned it was a little worse.
Any ideas?
wmsonta 06-27-2014 01:31 PM
Is it the front tire? Mine made a low howling noise when turning. New Shinko's fixed it.
Anyway, noise from the front tire area is never a good thing. I would continue until fixed.
berzerker1982-BL 06-27-2014 01:35 PM
Got nee shinkos on it....not sure what it is bit it comes. And goes almpst sounds like a card in the spokes on a peddle bike..... kinda worried
berzerker1982-BL 06-27-2014 01:36 PM
Could i have the wheel on to tight?
Spacer on wrong .iz was not lile this b4 i changed the tires
wmsonta 06-27-2014 01:39 PM
Does it make noise when turned by hand on the centerstand?
berzerker1982-BL 06-27-2014 01:42 PM
When i put the front on the spacer has a larger. OD on. One side and i put that larger side towards the forks is that right? Ialso get a simmiler noise when useing the front brake bit not as loud
berzerker1982-BL 06-27-2014 01:43 PM
It makesa rubbng sound from the brakes when on stand i thought was no big deal
wmsonta 06-27-2014 01:48 PM
Yes.
Do the rotors run true between the pads, when spinning the wheel by hand?
berzerker1982-BL 06-27-2014 01:53 PM
Tjey seem to be slightly warped
berzerker1982-BL 06-27-2014 02:01 PM
Just thought it was strange that the noise came and went i mean for the last 11 miles of my ride to work it was quite....but also thought it was strange that when the noise was there that it got worse by leaning mainly to the left
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
