-   VN750 General Discussion (https://www.vn750.com/forum/11-vn750-general-discussion/)
-   -   Starter Spins but wont kick in (https://www.vn750.com/forum/11-vn750-general-discussion/4966-starter-spins-but-wont-kick.html)
Bugg of steel 08-02-2007 01:39 PM
I bought a 86 VN750 Last year When my batery was low it would spin the starter but it wouldnt kick in to turn the motor over. I put a new batery on it and it started fine for a month. I haven't been able to get it started for a while now unless I pull it or push it down a hill. I put a new maint free bat on it still no luck. I took the starter apart it was a little oily inside but not bad. The brushes in the starter looked fine and it seems OK. Does anyone have an Idea what the problem is?
wwmkwood 08-02-2007 02:21 PM
there is a one-way clutch inside the right hand side of the engine that keeps the engine from continually spinning the starter. It sounds like it is not engaging.
Bugg of steel 08-02-2007 03:21 PM
When I take the starter out I can feel the clutch It catches one direction but will turn the other. Thanks
bj31702 08-02-2007 06:15 PM
Do you hear the starter relay click when you push the start button?
its under the right side cover
Bugg of steel 08-02-2007 08:11 PM
I have the Starter out. It Spins the relay kicks in I guess it is in that clutch.
bulldog485 08-02-2007 08:19 PM
How are the splines on the armature of the starter? The splines on the inside of the SC? Those are two things that could cause you issues. Also, check the teeth on the drive portion of the starter clutch and see if they are making contact with the flywheel.
Has your starter been load tested? One rare failure on starters is that the stack seperates from the shaft on the armature resulting in the stack spinning but the armature shaft not moving. I've never seen that happen on a Mitsubia starter, but it is something to look at too.
Bugg of steel 08-03-2007 03:53 PM
Every thing I can see without breaking into the crank case looks good.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
