-   Electrical (https://www.vn750.com/forum/19-electrical/)
-   -   VN 1985 stator burned (https://www.vn750.com/forum/19-electrical/39866-vn-1985-stator-burned.html)
jeankawa 09-02-2013 06:40 AM
Hi, just an update on my summer riding season that was going so well and then my battery started acting up. Thanks to the forum, I checked my stator wires output and got less than 10V charge. Well I did remove the engine enough to get access to the stator I found the thing severely damaged, blackened sections from shorting out I guess. I have a spare one and will put it back together when I receive my new gasket.
Fortunately, considering the age of the bike, I did not break or stripped any existing bolts, including muffler-manifold studs.
I do not foresee major issues putting it back together.
Funny, I was reading about unfortunate stator stories and I did not have a clue this would happen to me. Well I guess we all get there at some point.
thank you forum for the info.
jeankawa 09-03-2013 06:27 PM
gasket question
Hi, again, before I assemble the parts back to the engine, bevel gear and stator part, do you recommended pasting the joints with permatex hi-temp stuff along with stock gaskets.
new rider 9984 09-03-2013 06:47 PM
if you are using new oem gaskets you dont have to use any goo but it wouldnt hurt anything if you used a thin layer of the goo on the mating surfaces of the gaskets just as added protection from leaks
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
