-   Wheels, Suspension and Brakes (https://www.vn750.com/forum/27-wheels-suspension-brakes/)
-   -   Front Brake Pad Closest to the Piston falls out on install (https://www.vn750.com/forum/27-wheels-suspension-brakes/25586-front-brake-pad-closest-piston-falls-out-install.html)
bambang 03-30-2013 01:31 PM
Got a quick question that I can't find in any of the manuals. In reassembling the caliper assembly on the front brakes I've run into a slight problem. I can remove and re-install the pads (the pistons weren't a problem. Just let out a little bit of fluid and pressed down on the pistons until the pads came loose), but in re-installing the brake pads I can't get the small pad to set.
Well, I can get it to set by pushing down and back into the assembly - pressure from the anti-rattle spring seems to lock it into place.
When I push the pistons back however, this forces the brake pad forward and it simply pushes it out of the assembly. Looking for any advice on how to solve this before I go crazy. I'm not crazy, am I?
new rider 9984 03-30-2013 01:53 PM
keep fluckin with it you will get it that is one i could fix in ten seconds if i was there but i have no clue how to tell you to do it lol
bambang 03-30-2013 03:25 PM
THanks. I gave up. I think the gap between the two pads are too narrow by about a couple of millimeters. That'll learn me from buying from ebay.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
