-   Wheels, Suspension and Brakes (https://www.vn750.com/forum/27-wheels-suspension-brakes/)
-   -   Rust spots on forks (https://www.vn750.com/forum/27-wheels-suspension-brakes/19642-rust-spots-forks.html)
Oz. 08-29-2011 04:36 PM
Rust spots on forks
Another hurdle!
My forks have quite a few rust spots on them, they look like they got hit with a bad case of chicken pox!
Reading a few other sources I found suggestions to use very fine sandpaper, then polisher, other site suggested to use SOS pads and to keep them wet with diesel, other site suggested to buy new forks!.
Any suggestions here?
WilliamTech 08-29-2011 04:47 PM
Steel Wool available @ Home Depot & such. ..... Fine 00 or 000 ....Yes, your methods will work also.
Knifemaker 08-29-2011 05:56 PM
The question is...are the rust spots on the upper fork tube on the lower part of the tube that goes into the lower tube when the forks compress?
If so be very carefull on sanding there. If the bikes been ridden you might want to check the fork seals for leaks.
Make sure the rust is not do to dings or dents in the fork tubes.
JM2001 08-29-2011 05:57 PM
Originally Posted by Oz. (Post 186843)
Another hurdle!
I use 000 or 0000 steel wool WET out with Turtle Wax Chrome Cleaner and Rust Remover. After it drys I go over it with dry steel wool. Then apply one more coat of Turtle Wax Chrome Cleaner and Rust Remover with a clean cloth, wait for it to dry, and remove with clean cloth. :smiley_th
Oz. 08-29-2011 06:05 PM
the rust spots are on the upper part
I will try the steel wool tonight
Bronson 08-29-2011 06:05 PM
You might try fine (grey color) scotch brite. You can wrap around the tube and work it like a shoe shine. Chrome polish can work wonders too if there is no pitting.
Bronson
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
