-   Electrical (https://www.vn750.com/forum/19-electrical/)
-   -   How to wire an Electrosport r/r (https://www.vn750.com/forum/19-electrical/19107-how-wire-electrosport-r-r.html)
2kawaowner 07-11-2011 07:48 PM
I need to know what wires on an Electrosport r/r go to which wires on my 94 VN750. I know the 3 yellow stator wires are interchangeable, but I need to know about the other 3.
I think they should be like this:
RR Bike
Green Blk/Yel
Blk Brown
Red White
ourselfish 07-11-2011 10:05 PM
Bump, what advantages are there to using this r/r
ifixf18s 07-12-2011 11:49 AM
Maybe this will help you, though you may already know this information. The BLK/YEL wire is the ground, the WHT/RED wire in the positive. These two wires are used to recharge the battery and to run your lights or whatever other loads you have. The brown wire is the sensing wire, thats what ive heard it called on here. Its used by the Stock R/R to know what the R/R is putting out. Im not at home, so i would have to look it up to be absolutly sure but i think it goes to the ignition switch and when the ignition is on it gets its voltage sample from the WHT/RED wire. so maybe the other R/R wires are BLK= Ground, RED= positive, GREEN= some type of sensing wire. Thats my GUESS. I changed my stock R/R to a mosfet, the 3 non stator wires I was able to cap and stow. Didnt need them with the mosfet kit install.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
