-   Electrical (https://www.vn750.com/forum/19-electrical/)
-   -   Funky ""POOG" issue? (https://www.vn750.com/forum/19-electrical/18371-funky-poog-issue.html)
RYNODESIGNS 05-17-2011 02:24 PM
I've been reading about the POOG symtoms that occure at low fuel intervals, my weird thing is during the ride when its poping and sputtering, if I turn on the turn signals it will correct itself inbetween signal pulses, turn if off and problem is back.....was-up wit dat?....Also is the vaccuum port on the right side carb suposed to be blocked off?, on my 85 vn 700 with ear shaved, K&N pods,and straight pipes, no goat belly, or cross over for that matter..please help..anything helps.
Knifemaker 05-17-2011 05:25 PM
If it happens as you say, it is not are normal POOGS.... which is not electrical. So I would say yours is, and may be a bad coil or a loose wire in the ignition circuit.
RYNODESIGNS 05-18-2011 03:42 AM
Thanks KM,
but i can run the crap out of it in the garage and she purrs like a kitten, idles great, until I head out . Then she starts acting up, spittin, choaking and popping. All when the fuel gauge is at the top of the red, plenty. Thanks
RYNO
Knifemaker 05-18-2011 08:26 AM
Check the vacuum line going to the back of the right airbox.
If you have a bad connection it might not do anything with the bike sitting still. You move, it shakes or vibrates from the wind, and acts up.
A shorting wire can be a bitch to find.
RYNODESIGNS 05-19-2011 12:11 AM
where would that right side vent hose go since it's been shaved.? Right now it's capped off. Should it connect back up to the "T" inbetween the carbs?, there is one side of that T that is open....also, should the vent nipple under the gas cap(by the hinge) have a recipticle or vent hose to go into ? cause right now there is nothing.
clock152 05-19-2011 09:44 AM
The "T" should be connected between the carbs and then off to a filter.. it should not be capped... the right side vent line needs to be capped though... if your tank has a nipple on the rear of the tank it needs a hose ran from it to under the seat and out near the rear tire.
abyssdncr 05-19-2011 01:02 PM
I would check you vent line. Make sure that it's not plugged and hiding away from moving air. Good spot would be filtered and put where your fresh air valve used to be under the seat.
Had the EXACT same problem (minus the turn signal anomaly) last night and this was the culprit...
AZ Kev 05-19-2011 01:12 PM
So clock, just to clarify - you are saying the T itself should not be capped, but the right side vent hose should?
As far as I understand, the right and left side vent hoses go into the T, and then the one hose that comes off of it is supposed to go to the back of the right ear (if it were there), correct? I guess I am a little confused on this one.
:confused:
AZ Kev
Knifemaker 05-19-2011 01:16 PM
Yes, you should try an route it to someplace where there is still air. Air when the bike is moving can pass over an open hose end and change the air pressure inside the hose ( see how atomizers work ) so ... You don't want that to happen.
Up behind the steering neck under the gas tank is another good spot.
clock152 05-19-2011 01:25 PM
:confused:
AZ Kev
The T should be between the carbs.. 2 short hoses (1 from each carb) go into the T and then a long hose should go to the right ear.. this one should be filtered if you are shaved... the only one to be capped comes off of the right side carb (nipple on the outside bottom of right carb)... the hose orignaly went to the air valve under the seat but now has no where to go so it must be capped off.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
