-   Carbs and Fuel System (https://www.vn750.com/forum/22-carbs-fuel-system/)
-   -   yardstick (https://www.vn750.com/forum/22-carbs-fuel-system/14764-yardstick.html)
Rook 05-21-2010 06:25 AM
yardstick
I'm planning to do an earshave this weekend with the kit recieved from that most awsome and erstwhile personage Lance328 :notworthy I figured on checking the sync on the carbs once everything is back together just to be sure, but I can't find the link to the home made manometer. Does anyone know where to find that??
skalding 05-21-2010 08:39 AM
Rook 05-21-2010 09:49 AM
Originally Posted by skalding (Post 136887)
Many thanks. How did you do that? and why so mean, it's friday bro;)
93VN750 05-21-2010 10:08 AM
Works like a champ, chosse your fluid carefully as if the sync is way off, the carb with the higher vacumm will suck all the fluid out in no time flat.
Very small adjustments make a big difference.
I use 2 cycle oil, which smokes pretty good when it burns. Don't ask me how I know.
Jon
skalding 05-21-2010 10:12 AM
Sorry if it sounded mean, I just thought it was funny.
You really don't need a yardstick, BTW, you just need to adjust the screw so that the fluid is level with itself on both sides of the tube. I used a length of PVC piping and motor oil (drained it into the engine afterward). Make sure the tubing is tight on both vac valves and be prepared to hit the kill switch if one carb starts to pull whatever fluid you are using up into itself.
It's *very* easy to do.
Good luck!
Rook 05-21-2010 12:51 PM
^ It wasn't mean, I actually thought it was cool. I was just giving ya a hard time because it said " There, was that so hard?" before going to the search results.
Rook 05-21-2010 12:53 PM
Jon
I was thinking Seafoam, maybe with a drop or two of 2 cycle to make it easyer to see:smiley_th
OlHossCanada 05-21-2010 03:47 PM
Or some red Automatic Transmission Fluid.
wkrizan 05-21-2010 03:59 PM
That google link was the chitz...cant stop laughing here.........:notworthy
AirForce1 05-22-2010 09:14 PM
DUDE!!!! That link thing was friggin' hilarious!! Damn! I WILL learn how to do that ASAP!!:rockon:
________
silver surfer vaporizer
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
