-   VN750 General Discussion (https://www.vn750.com/forum/11-vn750-general-discussion/)
-   -   OK you bunch of "know it alls"..LOL!! (https://www.vn750.com/forum/11-vn750-general-discussion/101826-ok-you-bunch-know-alls-lol.html)
vulkan 05-11-2018 07:19 PM
So thinkin this question been on here BUT...possibilitie of putting a (minds out of the gutter...) LONGER oil filter for more capacity.Yes...no?? :smile2:
Spockster 05-11-2018 07:24 PM
I'll take a longer one if I can find it, but I don't hunt for them anymore.
One1 05-12-2018 01:13 AM
:huddle:
Knifemaker 05-12-2018 11:50 AM
Actually the filters now available for the bike are in fact longer than the original ones Kawasaki used when the bike came out.
Also a"longer" filter doesn't really filter more oil. Oil flows at a given rate through the channels in the bike. The filter they use is designed to not interfere with this, (unless badly clogged) so making one a bit longer isn't going to increase oil flow, it will only take longer to completely clog.
If you change you filter with every scheduled oil change, as many do, there be no advantage in using a longer filter.
If your filter is clogging up quickly, there's something wrong with your bike ;)
Jason Pittenger 05-12-2018 06:30 PM
My friend's VW Passat had issues with oil sludge and VW's solution was a larger oil filter.
The larger filter increased the capacity from 4.3 qts to 4.8 qts.
This resulted in a lowered oil temperature, reducing the formation of sludge.
Yes, a VW Passat is not the same as the VN750, but increasing capacity should have the same effect of lowering the oil temperature.
It will also slightly extend the life of the oil, as there's more of it to become contaminated/break down.
I don't see any negative affects, other than having to buy more oil each time.
Whether or not it's worth the cost, I couldn't say.
Knifemaker 05-13-2018 10:21 AM
If you have a problem with sludge... a larger filter isn't going to fix the issue, just help mask it.
I'll go back to the OP here and ask, what filter did you find that's bigger for the Vulcan?
OleDirtyDoc 05-13-2018 02:19 PM
Hmmmmmmmmmm.......[emoji6]
Spockster 05-13-2018 08:40 PM
https://memegenerator.net/img/instan...97/uhhhnah.jpg
Thorn 05-14-2018 02:30 AM
I was going to ask, what's hotter, 2.3 qt of 200 degree oil, or 2.8 qt of 200 degree oil? >:)
michiganteddybear 05-14-2018 09:24 AM
answer: 2.x qts of 200 degree oil!
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
