Painting engine question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 17 (permalink) Old 11-29-2017, 10:55 AM Thread Starter
I had an accident last month and since I'm having to replace a few things (rip Vance and Hines pipe) I decided that this is the perfect time to paint the engine. I'm basically doing a complete tear down and re-painting/polishing everything down to the last bolt. So that brings me to the engine. I'll be using the VHT high temp gloss black paint and taping off the fins/all chrome. I would also like to keep all the bolts on the bike chrome. So short of meticulously taping off every bolt, what's the best way of doing this? I was think about doing a rough tape round all the bolts and then completely finishing the rest of the engine and then taking off tape, unscrewing bolts slightly, taping them off and then spraying around/under bolts. I already have a non leaking solid engine so in the process of unscrewing each bolt one by one and painting I would hate to cause any issues and I'm aware that some/ if not all bolts will need to be torqued to specs, which is fine but would prefer to not have to replace any gaskets and such if doing the above process warrants it. Also, what about the cylinder head gasket and other rubber parts on the engine, can those be hit with the VHT or should they be taped off? I'm looking to turn this VN to near showroom quality so everything will be meticulously cleaned/replaced and when I'm done I don't want to look back at 1 bolt and go "should have taken more time on that" so response from that standpoint would be greatly appreciated.
Thanks
MikeIronTyson is offline
post #2 of 17 (permalink) Old 11-29-2017, 01:05 PM
We didn't bother with the 'every bolt' thing. It would have taken forever!
If you're loosening 1 bolt at a time and re-tightening, it won't affect the gasket. If you have an entire covers set of screws loose, it could mess with the gasket.
We hit the rubber parts of the valve cover gasket with the VHT, seems fine so far.
post #3 of 17 (permalink) Old 11-29-2017, 01:08 PM
only way I can think of would be to tape all the bolts, OR, get new replacement bolts, and change them out after painting is done. doing one at a time *should* retain all the gasket seals and such.
might look into some sort of coating to put on the bolts that can be peeled off after painting, but I dont know of one off hand
post #4 of 17 (permalink) Old 11-29-2017, 02:07 PM
WilliamTech3's Avatar
Cool
I've never tried it, but maybe Vaseline or other oil base substance....brushed on bolt heads with a very fine paint brush ?
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #5 of 17 (permalink) Old 11-29-2017, 02:41 PM
The time it would take to carefully coat each bolt with Vaseline or some easy to remove coating would likely take longer than just painting them, them backing them out and stripping the paint off (with a wire wheel in a dremel tool, or just solvent and a rag)
I'd likely remove each, one at a time ....then replacing, after polishing the heads to a mirror finish. Just chuck the bolt in a drill and use a pad with a fine metal polish. That against the black cases would look awesome
thtanner likes this.
post #6 of 17 (permalink) Old 11-29-2017, 03:05 PM
Cool
I agree with KM.....then clearcoat or clear finger nail polish to prevent future rust.
Since May 2011
post #7 of 17 (permalink) Old 11-29-2017, 09:29 PM
X2 on both of these! It kinda sucks but its the best way if you're going for quality.
- "Every normal man must be tempted, at times, to spit on his hands, hoist the black flag, and begin slitting throats."
'92 VN750
AGM battery, Iridium Spark plugs, Repaired/upgraded wiring per Mcinturff method, RLU removed, Repaired shift linkage, Exhaust baffles removed, Black ISO grips installed, installed SH775 R/R, Ignition coil relay mod, replaced stator housing.
Future projects: whatever it takes to keep riding
Currently working on: Light bar, LED upgrades, Dash cleanup/paint
TR_Irish is offline
post #8 of 17 (permalink) Old 11-29-2017, 11:27 PM
clean,decrease,clean,decrease AGAIN,clean,and sand any corrosion. oh, did I say clean?
post #9 of 17 (permalink) Old 12-19-2017, 11:00 AM Thread Starter
This is how I'm going to do it, thanks. Since you made the Torque Value thread, I have a question for you. I'm about to do the tuxedo mod and replace the dampers while I have the engine out and I cannot find anywhere between the two manuals where it mentions the torque values for the mounting bolts on the inside alternator cover. I have some dificulty decifering the different terminoligy for the engine section of torque values.
post #10 of 17 (permalink) Old 12-19-2017, 03:09 PM
You say you looked here?:
https://www.vn750.com/forum/11-vn750-...ue-values.html
Do you mean stator?
Tags
bolts , engine , paint
