Jumping into the shallow end - Page 4 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #31 of 39 (permalink) Old 07-10-2018, 05:08 PM
Looking sweet
post #32 of 39 (permalink) Old 07-10-2018, 07:55 PM Thread Starter
Originally Posted by Thorn View Post
Well that's a cryin' shame. At least they'll look sexy until they don't!
You may notice that the bezels aren't on anymore
LandyLou is offline
post #33 of 39 (permalink) Old 07-10-2018, 08:42 PM
Try to get your hands on a voltmeter to verify your gauge reading, but it's obviously reading low or getting low volts from that location. "Low 11s" would be totally dead, but we know better since it starts up and rides.
I like those rear turns.
post #34 of 39 (permalink) Old 07-11-2018, 12:51 AM Thread Starter
Looking sweet
Thanks, man!
Already got one from amazon, should be here Thursday. I was pretty sure I was getting low reads So will this voltmeter be of any use? If I figure out the difference between "true" and "read", is it a linear progression (i.e. always reads 1v lower than true)? Or will I need to wire it in somewhere else and figure out another way to have it not draw power when the ignition is off?
LandyLou is offline
post #35 of 39 (permalink) Old 07-11-2018, 07:22 AM
lugnut1009's Avatar
Originally Posted by LandyLou View Post
Thanks, man!
I would think the difference would be linear but you really have no way of knowing for sure unless you had a variable voltage source you could turn up and down to compare it to.
-2016 Indian Springfield
Chieftain bars
Roadmaster heated seat
-1999 Kawasaki Vulcan 750
Ear shaved
Mufflers removed / 38/140 + 2 shims
Relay coil mod
Pick-up coil mod
Emissions removed
Lowered rear
Rear blinkers located in tail light housing
Petcock gutted
- Wife's: 2018 Can-am Spyder F3 Limited Pearl White
lugnut1009 is offline
post #36 of 39 (permalink) Old 07-11-2018, 09:12 AM
The accessory leads behind the right side cover may be a better source if it turns out the voltage drop is at the turn signals.
On mine, I connected the positive to the battery, and ran the negative side through a toggle switch. Make sure it's waterproof if you do a switch, mine wasn't and corroded in 3-4 years.
post #37 of 39 (permalink) Old 07-12-2018, 09:22 PM Thread Starter
Got the handheld voltmeter today, much happier with the new readings. 13.1 off, 13.8 at 6k rpms (I donít think I need to be actually cruising; I can just have it in N and rev it up, right?) I measured from the battery tender leads, which is hooked directly the the battery of course, and should give me a pretty good reading.
The unfortunate part is that the difference between readings at the battery and readings where the voltmeter on my bike is currently installed is not linear. I guess I just have to make an educated guess and if the voltage drops below what the voltmeter normally reads to start checking things out....
LandyLou is offline
post #38 of 39 (permalink) Old 07-23-2018, 01:50 PM
kryptonianjorel's Avatar
Do you have a battery tender lead wired up to the battery? If so, just get a battery tender cable and use that for your voltmeter. I just disconnect the voltmeter when I am using the tender, and hook it back up when I'm ready for a ride
kryptonianjorel is offline
post #39 of 39 (permalink) Old 08-16-2018, 03:10 AM
Prometheus
TheModernLemonade's Avatar
Got the new NGK Iridium spark plugs in today. Now she fires up from cold with barely a touch of the button! Thanks to everyone on this forum posting up good advice and helping each other out!
It's reasons like this that I read.
TheModernLemonade is offline
