Restoring estanner's 1990 VN750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 32Likes
post #1 of 53 (permalink) Old 04-08-2017, 11:46 PM Thread Starter
After about 5 years of sitting in the back of the garage, it's about time to roll out the '90 and take her down to frame, clean everything up, fix the broken bits, and put her back together. I have a bunch of new(er) parts to put on like a new tank, upgraded brake stuff, mosfet r/r, whatnot.
After spending most of the day re-organizing the garage for the tasks (5 bikes, tools, and a parts cache is quite the squeeze,) I managed to take care of a few things before it got dark.
  • Drained oil
  • Removed seat
  • Removed battery
  • Removed toolbox
  • Removed side covers
  • Removed rear fender/sissy bar support
  • Removed exhaust & gasket
  • Removed engine guard
  • Removed passenger pegs
You know you're doing it right when there's a big hammer
We'll hopefully finish disassembly tomorrow, as well as internal engine work. That will leave the weeknights this next week for paint (frame, engine, etc,) with reassembly next weekend if I'm lucky.
Gaz73 likes this.
post #2 of 53 (permalink) Old 04-09-2017, 06:28 AM
Tinkerer
Gaz73's Avatar
Nice one buddy, good luck with the strip down and rebuild
thtanner likes this.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #3 of 53 (permalink) Old 04-09-2017, 10:03 PM Thread Starter
Made some progress today. Almost as much as planned, but I got a late start.
  • Drained coolant
  • Removed radiator and associated coolant hoses
  • Removed the ears
  • Disconnected airbox from carbs
  • Disconnected clutch cable
  • Disconnected electrical connections from engine, starter, etc
  • Removed coolant bottle
  • Supported to engine with 2x4 and jack
  • Removed engine mount bolts and removable frame section
  • Trashed smog items
  • Wiggled engine out. The removable motor mounting location on the right side made this a lot easier.
  • Removed carbs off engine
  • Trashed airbox
Gaz73 likes this.
post #4 of 53 (permalink) Old 04-11-2017, 09:55 PM Thread Starter
Tackled the interior engine work. The timing is super simple to keep set with the notch in the rotor and damper.
  • Replaced stator (TPE rewind, under 10k miles used from my 86 that I replaced thinking it was an issue .. it wasn't)
  • Replaced balance dampers
  • Replaced shift-shaft seal
  • Adjusted shift-shaft circlips to eliminate play (someone had dropped the bike before, so it had way too much in and out play)
  • Torqued everything to factory spec
  • Engine now ready for paint prep
Gaz73 likes this.
post #5 of 53 (permalink) Old 04-13-2017, 07:00 AM
Tinkerer
Gaz73's Avatar
Nice work buddy, you are going full steam ahead
Gaz73 is offline
post #6 of 53 (permalink) Old 04-13-2017, 11:47 AM Thread Starter
Cheers Gaz.
I don't think I'll have it together as fast as planned, but if I can get a lot of the stuff painted this weekend I'll be happy.
Would be nice to have it together prior to the end of the month. I'm tackling carbs here this week after I work up the patience to deal with them.
post #7 of 53 (permalink) Old 04-13-2017, 12:25 PM
Tinkerer
Gaz73's Avatar
Got to admit, it took lots of counting to 10 and deep breathes rebuilding mine... Kawasaki like to over complicate things
Gaz73 is offline
post #8 of 53 (permalink) Old 04-13-2017, 06:09 PM
looking good. ahhh, memories...
post #9 of 53 (permalink) Old 04-13-2017, 07:28 PM
Refeal
I did the floats on my carbs for my vn750 '86 they were a huge pain in rear end , because they are not a normal angle they are setup on a 45 degree angle grrrr super frustrating. I also had short patience with linkage. cheers
thtanner and Gaz73 like this.
live to ride, ride to live.
Laefer Lewis is offline
post #10 of 53 (permalink) Old 04-14-2017, 04:56 PM
Tinkerer
Gaz73's Avatar
Yup it's a fiddly ba$t45d ... I was so close to lobbing the whole lot across the workshop floor
But a walk away, two cups of coffee and a lot of swearing later, it finally came together
Gaz73 is offline
