'86 VN750 Rebuild Problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 01-26-2017, 12:45 PM Thread Starter
Question '86 VN750 Rebuild Problems
Hey guys, I'm finishing up my rebuild of my entire bike. I brought her down to the bare frame, painted everything, ear shaved, de-goat, rejet, stuff like that. Pics will be coming soon
I believe I have everything hooked back up correctly. Lights go on when you turn the key, she starts, but there's coolant in the engine oil. The first time I started her it took a little bit to run. After a minute or two I shut her back off. When I looked in the oil peek hole, it was completely empty. I threw another quart in there and she seemed fine. I started her the next day, same thing. Ran out of oil. After a second though I turn her back off and see milky green oil in the peek hole. ****. I saw coolant dripped out of the headers and made a little pool on the engine block. I haven't checked whether oil seeped into the coolant by looking in the coolant filler cap.
I may be looking at the water pump seal or head gasket blown. Worst case scenario, cracked engine block. Anything you guys can think of? Any information will be very useful right now because I am at my wit's end with this bike.
'86 VN750
snoopyonderdonk is offline
post #2 of 4 (permalink) Old 01-26-2017, 02:10 PM
Nickdwhit's Avatar
Is it smoking at all? That's a good sign if it's the head gasket
Nickdwhit is offline
post #3 of 4 (permalink) Old 01-26-2017, 10:18 PM Thread Starter
It smoked a little when I FIRST started her. I think it may have been steam though. Not sure. I don't see any smoke really now
'86 VN750
post #4 of 4 (permalink) Old 02-03-2017, 05:51 PM
with yr description i would say milky green oil is defo water in oil and head gasket is the first i would look at, however you seem to be losing a lot very quickly (initial start up from rebuild you will have to top up as oil needs to fill everywhere, however with the water not so much as you do have a bleed nut) also you mention coolant leaking from headers, because of this i would be more inclined to check the water pump and any other seals as its seems to much going into oil too quickly for head gasket.
good luck keep us updated please
paulbute is offline
