Engine paint / Exhaust wrap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 13Likes
post #1 of 30 (permalink) Old 01-14-2017, 08:08 PM Thread Starter
VulcanMKE's Avatar
Hey guys, so I got some plans for the Vulcan this winter, seeing as how it's cold here in WI. I'm going to be putting new handlebars on, seat, custom pipes (I removed the baffles on it so far, sounds MUCH nicer), etc etc. OF COURSE I will be posting pictures, no need to ask friends!
So questions for the experts:
What do you think about engine paint? I know there's high temp resistant spray paint out there that you can spray on your engine. Anyone have experience using it? I know it's easy application, but do you think it's safe and won't cause any inner damage?
Secondly, what do you think about exhaust wraps? I hear good and bad things about it and I want to get your opinions on it. I think it would look real cool and also save my inner thighs from getting burned since I took off the baffles.
I guess these aren't real questions, just asking for opinions.
Thanks again!
YouTube : VulcanMKE
Instagram : vulcanmke
VulcanMKE is offline
post #2 of 30 (permalink) Old 01-14-2017, 09:10 PM
I'm working on my VN750 build and doing exactly what you described. So far I've got the engine and exhaust painted with 2000 degree F engine paint (as exhaust pipes can get really hot) and bought high temp wraps too. You should be good if you mask everything off properly and use the included hardware for the wraps. Unfortunately my bike is still in progress and can't start it up yet, so I have to wait to see how it fairs. Good luck!
OleDirtyDoc and VulcanMKE like this.
'86 VN750
snoopyonderdonk is offline
post #3 of 30 (permalink) Old 01-14-2017, 09:26 PM
did you guys spray the engine or just the pipes? the proper way to do the aluminum cases is to prime them with a special primer that etches the aluminum so the paint sticks to it.
as for wraps, i have it here to do a set of pipes. i just havent taken the time to do it. may wrap the kz pipes this winter
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #4 of 30 (permalink) Old 01-14-2017, 10:11 PM
I've had good luck with VHT brand engine paint.oh if you have outside cats don't let them near wrapped pipes.can you say scratching post?the next question? can you say pork fried rice?hear kitty kitty hear kitty kitty
post #5 of 30 (permalink) Old 01-14-2017, 11:45 PM
mayor of Narnia
minikrew's Avatar
bad doc just bad
OleDirtyDoc likes this.
new supetrapp mufflers
led turn lights
talked to wolfie got highway pegs
to late to bring back wolfie now ride on brother
degoated
new rear drive & splines lubed h-pipe installed riding on the darkside
minikrew is offline
post #6 of 30 (permalink) Old 01-15-2017, 12:40 AM
meeeeeeoooooooooow.just kidding of course
minikrew likes this.
post #7 of 30 (permalink) Old 01-15-2017, 02:49 AM Thread Starter
VulcanMKE's Avatar
Well good thing my cat isn't an outside cat. Good advice nonetheless!
Sent from my LG-H900 using Tapatalk
YouTube : VulcanMKE
post #8 of 30 (permalink) Old 01-15-2017, 04:33 AM
almost killed that damn cat
post #9 of 30 (permalink) Old 01-15-2017, 02:32 PM
Most high temp paints won't completely cure until they are heated up. What this means, until you fire up the motor and get it cooking, the paint will scratch more easily, so be careful.
Back in the early 80's, folks were painting various engine parts black because they heard black disperses heat better. Which it does, but the difference is rather small..
http://www.offroaders.com/tech/paint-it-black.htm
post #10 of 30 (permalink) Old 01-15-2017, 02:49 PM Thread Starter
VulcanMKE's Avatar
This is good to know, thanks. So paint it and run the engine for a bit afterward?
YouTube : VulcanMKE
