kz400 to get upgrades - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 13Likes
post #1 of 23 (permalink) Old 12-31-2016, 09:53 PM Thread Starter
while im waiting for vulcan parts, the kz is going to get some much needed upgrades. 15 inch apes, mikuni vm30 round slide carbs with new manifolds, fuel lines and a 1-2 throttle cable. motion pro extended clutch cable, and new throttle and control levers. if i can find the right size wheels im gonna go with disc brakes all around. rear sissy bar, side mount license plate with leds, new signals and headlight. probably extend the forwards if i stay with mechanical brakes.
OleDirtyDoc, Gaz73 and NIBiker like this.
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #2 of 23 (permalink) Old 12-31-2016, 11:04 PM
looking sweet Dave.bring that bitch to strange days.hope to have the ironhead done by then,but don't count on it.will probably be on my goldwing
post #3 of 23 (permalink) Old 12-31-2016, 11:33 PM Thread Starter
84 honda 21 inch front wheel with disc brake and 16 inch kz550 rear disc brake wheel will work with needing new axels........
OleDirtyDoc likes this.
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #4 of 23 (permalink) Old 01-01-2017, 11:14 AM
Tinkerer
Gaz73's Avatar
Wow, now that floats my boat looking good Goofin
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #5 of 23 (permalink) Old 01-01-2017, 08:16 PM Thread Starter
thanks, after todays ride to support the humane society was done, i was able to start tearing it down. apes are on so when the new carb set up gets here i can start working. new apes are on, measured fro new cables and will call motion pro on tuesday to get them started. tonight im looking at all new hand controls and mirrors. thinking of going to a round femder and a tall sissybar. if i can find a coffin tank in the 4 to 5 gallon range. ill grab it.
OleDirtyDoc and Gaz73 like this.
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #6 of 23 (permalink) Old 01-01-2017, 11:34 PM
good looking scoot goofin, but that skinny seat makes my butt hurt just seeing it. lol
post #7 of 23 (permalink) Old 02-03-2017, 08:48 PM Thread Starter
Work has kept me busy to do much at all. but got most of the parts now. new carbs, clutch and front brake cable, new throttle cable assembly for the carbs i have to cut and solder. new sprockets and chain. waiting on the welder to get here, should be here saturday. then i can do the side mount license plate and sissybar. need to get this back together so i can start on the vulcan. found a place that will make me a conversion sprocket for the transmission so i can use a bolt on trike rear. wont be too much to manufacture that way and ill be able to do it for a lot less
OleDirtyDoc and NIBiker like this.
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #8 of 23 (permalink) Old 02-03-2017, 09:38 PM
sweet
post #9 of 23 (permalink) Old 02-04-2017, 05:24 AM
Tinkerer
Gaz73's Avatar
Plenty going on, looking forward to seeing the end results
Gaz73 is offline
post #10 of 23 (permalink) Old 02-04-2017, 03:34 PM
just recently got my old kz440 frame back with both of my xs400's. and my gs400 motor.might go through the gs motor and put it in the 440 frame.
