R/R Relocated! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By Monnerjr
  • 1 Post By OleDirtyDoc
post #1 of 10 (permalink) Old 10-01-2016, 02:01 PM Thread Starter
R/R Relocated!
I did mine a bit different than most, mounted it right behind the side cover. I think it still gets plenty of air flow and the gap between the r/r and box should be plenty enough the heat shouldn't effect anything.
ID:	34361   Click image for larger version
ID:	34369   Click image for larger version
ID:	34377   Click image for larger version
ID:	34393   Click image for larger version
Gaz73 likes this.
MonnerJr
Monnerjr is offline
post #2 of 10 (permalink) Old 10-01-2016, 03:51 PM
that should work. the idea is to get it away from the heat of the goat's belly
Monnerjr likes this.
post #3 of 10 (permalink) Old 10-01-2016, 05:24 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Does anyone just happen to know how much heat the goats belly gives off in degrees? People tend to relocate their RR (and I am also thinking about doing that sometime later on) but has anyone tried to run some ducting perhaps from a cooler air source to the stock-positioned RR instead? I haven't thought about that possibility until sitting right here typing this so I'm not sure how you'd even do it, but cooler air is cooler air. A few years back I had thought about maybe drilling some holes in the side cover forward-facing part so as to possibly get some more airflow but I didn't think of actually ducting air in. Nice pics Monnerjr. Good job.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #4 of 10 (permalink) Old 10-01-2016, 07:00 PM
Same here, works fine. Mine is cool to the touch usually.
post #5 of 10 (permalink) Old 10-01-2016, 08:36 PM
The goats belly does get pretty hot. Don't have a running Vulcan to get an actual reading, but I'll bet you can boil water on it, so that's at least 212F.
I did think about making an insulated heat shield to put between it and the R/R, and cutting vents in the side covers to channel more air towards it.
Really just seemed easier to move it out board like many have done, or move it behind the side cover like tanner.
I've posted before that there's no real proof moving the R/R does anything, it's just something that "sounds like a good idea". I never moved mine, and never had any problems.....
post #6 of 10 (permalink) Old 10-01-2016, 11:37 PM
it'll melt plastic
post #7 of 10 (permalink) Old 10-05-2016, 09:26 PM
I'm a rider
One1's Avatar
Long as it stays below a certain temp you're good. Personally I think the brain of the bike gets too much heat already so I wouldn't want anything else that close to it and some RR's get toasty. The best mod is to dump that goat and let her breathe.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #8 of 10 (permalink) Old 10-10-2016, 01:13 PM
Expendable newbie
evulcannibal's Avatar
I did mine similar in the way that it is in left side cover. However where mine differs is that I didnít use any mounting brackets. I just glued the r/r to the fuse box cover. I can still access the fuses since itís just glued to the cover.
Does the r/rís body need to be grounded, because Iíve been running like that for a while and I was wondering if it needs to be.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #9 of 10 (permalink) Old 10-10-2016, 05:43 PM
I've always been told to ground the r/rs on the frame. That being said, i'd be worried about the glue failing due to the temperatures and vibration, but some glue/epoxy is pretty amazing.
post #10 of 10 (permalink) Old 10-14-2016, 11:54 AM
Expendable newbie
I used gorilla epoxy glue. I've been riding with the r/r glued and frame not grounded for a couple of months now. Doesn't seem like it's melting.
I don't know how hot the r/r gets though.
I know some r/r is grounded through the frame, but isn't one of the connecting wires the ground wire for our r/r.
95 VN750
Blacked out engine
Gear indicator
