Barn bike breathing again - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-15-2016, 10:26 PM Thread Starter
LOTTO's Avatar
Got the carbs put on and started her up Probly the first time it's ran in 3 years sounds ok think my float level might be off as I had to shut the gas off to keep from overflowing "tw200 petcock" also my ignition switch has a short or bad connection has anyone ever takin one apart any suggestions would be appreciated
LOTTO is offline
post #2 of 10 (permalink) Old 06-16-2016, 01:51 AM
Try Wolfie's backblow method on the carbs.might have stirred up some gunk and got some dirt in the float needles
post #3 of 10 (permalink) Old 06-16-2016, 01:54 AM
And try here on the ignition switch
https://www.vn750.com/forum/showthread.php?t=14214
post #4 of 10 (permalink) Old 06-16-2016, 02:13 PM Thread Starter
LOTTO's Avatar
Tried it with no luck. Took carbs off found the spring loaded end of my front needle was stuck closed replaced with one from my spare carb and no more leaks.
However if I ease into the throttle she runs great but if I dump the throttle it's like she is struggling and wants to die is this a mixture issue
LOTTO is offline
post #5 of 10 (permalink) Old 06-16-2016, 03:01 PM
Don't remember how your bike is set up
post #6 of 10 (permalink) Old 06-16-2016, 03:20 PM Thread Starter
LOTTO's Avatar
I did the ear shave and coaster because it was cheaper than buying all the molded hoses and vacuum lines that were either missing or damaged. Didn't think it was a jet issue because as long as I don't throttle fast everything sounds great
LOTTO is offline
post #7 of 10 (permalink) Old 06-16-2016, 04:04 PM
What exhaust?
post #8 of 10 (permalink) Old 06-16-2016, 04:56 PM Thread Starter
LOTTO's Avatar
Stock
LOTTO is offline
post #9 of 10 (permalink) Old 06-16-2016, 06:58 PM Thread Starter
LOTTO's Avatar
Ignition fixed cleaned all contacts but the problem was the plastic cover on the bottom was only being held on by 2 prongs I geuss 30 years took its toll. some 2 part appoxy and it's as good as new
LOTTO is offline
post #10 of 10 (permalink) Old 12-15-2016, 09:50 AM
Hello....What "plastic cover are you referring to in your last post?
tonyd is offline
