My next project - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-10-2016, 08:36 AM Thread Starter
My next project * with updates
Picked it up last night. 94 with approx 14,000 miles. The guy thinks it has a bad stator. Bike hasn't run in at least 2 years. We put a charger on it and it does crank over. He even had a new stator & gasket to go with it, along with a windscreen and a set of thow over saddle bags. All for $600.
post #2 of 16 (permalink) Old 05-10-2016, 09:11 AM
Nice find
post #3 of 16 (permalink) Old 05-10-2016, 09:38 AM
Tinkerer
Gaz73's Avatar
excellent
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #4 of 16 (permalink) Old 05-10-2016, 11:18 AM
Perfect
post #5 of 16 (permalink) Old 05-16-2016, 09:56 PM Thread Starter
Finally got it running tonight! Hooked it up to a car battery. So hopefully I can do some output tests on the stator this week. Maybe I'll get lucky and it will just be the R/R, doubt it though. I don't usually get that lucky.
http://vid559.photobucket.com/albums...psoq5sibml.mp4
post #6 of 16 (permalink) Old 05-16-2016, 10:05 PM
Sound good.I like those blue dot signals and taillight
post #7 of 16 (permalink) Old 05-17-2016, 12:59 AM
Expendable newbie
evulcannibal's Avatar
It may not be fully fixed but it's always a good feeling to get a project bike running again. That way you at least get an idea of the condition that it's in. It sucks when you've done all you can think of and it still won't run.
evulcannibal is offline
post #8 of 16 (permalink) Old 05-17-2016, 07:20 AM
Tinkerer
Gaz73's Avatar
Nice one
Gaz73 is offline
post #9 of 16 (permalink) Old 05-18-2016, 08:31 PM Thread Starter
OK, Started up again tonight and tested the lead's from the Stator. My AC output cross checking all 3 leads was 43 across the board, so now I'm thinking the R/R might be the problem.
Also had no continuity between each leg to the Engine casing. So that checked out.
post #10 of 16 (permalink) Old 05-19-2016, 12:55 AM
Nice looking scoot you have there sharky.
The only things that are apparent to need attention are rings on the speedo and tach need a good polishing, and one missing mirror.
Could you take some close ups of the front fender decoration as well as the clutch cover, horns and little blue thing under the front of the tank?
