Scratch to Vulcan in days - part DEUX - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 19Likes
post #1 of 31 (permalink) Old 04-19-2016, 05:27 PM Thread Starter
I'm a rider
One1's Avatar
Time for me to do it again with this Vulcan I picked up in the classifieds. Had to rebuild the engine, then tear it down and start from scratch so everything was properly lubed and maintained. I won't ride it if I haven't set every screw in it myself. As with the other bike, This will be a frame up build. This time it won't be a cream puff, This one will be a bobber with some custom accents and blacked out a lot of places.
I have some of it assembled, but have to tear it back down because I was just mocking up the suspension to where I want it to sit. The forks are 4 inches down.The rear will be relocated. I redid all the electrical harness, have to put it back in.
ID:	30722   Click image for larger version
ID:	30730   Click image for larger version
ID:	30738   Click image for larger version
ID:	30746   Click image for larger version
OleDirtyDoc, RoadHopper and Gaz73 like this.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #2 of 31 (permalink) Old 04-19-2016, 06:35 PM
Nice
One1 likes this.
post #3 of 31 (permalink) Old 04-19-2016, 09:06 PM Thread Starter
I'm a rider
One1's Avatar
hour later, engine is in
OleDirtyDoc and RoadHopper like this.
1981 KZ750
One1 is offline
post #4 of 31 (permalink) Old 04-19-2016, 09:15 PM
RoadHopper's Avatar
No jack?
RoadHopper is offline
post #5 of 31 (permalink) Old 04-19-2016, 09:24 PM
That is as far I have my engine installed....bet you have your installation completed before I do mine - -
LOL
post #6 of 31 (permalink) Old 04-19-2016, 11:28 PM Thread Starter
I'm a rider
One1's Avatar
New personal record for me. I've done everything but the plumbing and exhaust in 5 hours. It's wired completely up, just have to do coolant and exhaust. Will test ride it tomorrow.
ID:	30810   Click image for larger version
OleDirtyDoc likes this.
1981 KZ750
One1 is offline
post #7 of 31 (permalink) Old 04-20-2016, 04:22 AM
Tinkerer
Gaz73's Avatar
excellent buddy
Wish I could 5hrs straight to work at my bike lol
One1 likes this.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #8 of 31 (permalink) Old 04-20-2016, 02:12 PM
The VN goes together pretty darn fast once you know what goes where. Bet you can get it down to 2-3 hours if you do a few more.
Heck, can probably start flipping them on CL at that rate
OleDirtyDoc, WilliamTech and One1 like this.
post #9 of 31 (permalink) Old 04-20-2016, 02:37 PM Thread Starter
I'm a rider
One1's Avatar
It does indeed go pretty fast once you have it down. Should be riding it tonight and hoping the fresh engine is timed right. I had a moment of doubt on whether or not the rear head was on the right tooth for the lower sprocket, but 1 tooth wont cause any damage if it isnt. It'll just run like shAt and I'll move it a tooth over. I think it's right. The piston goes to TDC on the first pin, stays there for the second pin, and drops at the 3rd pin, which totals a tooth and a half. The front of the engine was already timed to be on the third pin when the piston just starts its downstroke and hasnt actually moved yet so I set the rear to be the same so they at least match. I can't set it at either of the others because the tooth isn't available for them.
Daytime pic of where I left off last night. Did all the electrical, headlight, not using turn signals on this bobber so left them off, Have to figure out a brake light cause I want the rear tail smooth, Just need to bolt the exhaust, do the cooling and oil. tank and seat are a 2 minute job.
ID:	30826   Click image for larger version
1981 KZ750
One1 is offline
post #10 of 31 (permalink) Old 04-22-2016, 01:17 AM Thread Starter
I'm a rider
One1's Avatar
First pic shows the drop on the front forks. She's riding low.
Second and third pic are from today when I wheeled them both out complete.
ID:	30929   Click image for larger version
ID:	30937   Click image for larger version
1981 KZ750
One1 is offline
