OVERHAUL - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 13Likes
post #1 of 69 (permalink) Old 04-13-2016, 10:36 PM Thread Starter
RoadHopper's Avatar
OVERHAUL
This thread might be something done before... but...
As of this morning, it took about 2 or 3 months to finally determine the "reality" shape of this bike. It has been determined that the engine must come out for a rebuild. And so a stator mod will be done "properly" instead of cutting out the plate while the bike is on the stand.
On the way "there". Need to pull the rear tire anyway, so, will be doing the splines inspection... and the electrical harness is 30 years old and the entire bike is going to be rewired anyways because i want a custom dash that has 3 toggle switches, and a couple of meters on it... so... at that point... may as well sand off the frame and paint her too.. remove the emissions, etc... etc... etc...
SOOOooooo the question here for "Overhaul" is...
What is the suggested order of operations for tearing a full bike down to its core... and rebuilding it?
This is more than just asking the order that "needs" to occur, but based on supply of parts... while waiting on "xyz" bearing to arrive... need to be working on something else anyways, etc... This is a question that can only be answered by "opinions", certainly, but i am hoping to hear how various people arrived at those opinions, and why.
Thanks in advance.
RoadHopper is offline
post #2 of 69 (permalink) Old 04-14-2016, 03:08 AM
You can tear the bike down in 2 hours or less. Literally every bolt. So that's pretty quick. Get the bike a part, then get to your engine.
You wont know what you need (aside from standard gaskets) until you break open the case and inspect it.
Order from a local dealer to get parts 3-5 days faster than online. Have them come close to online prices - they will if you are ordering a bunch (i.e. full rebuild stuff).
There is no rebuild 'kit', so you need to spec each gasket part # etc.
While you have parts down time on the engine sort out just about everything else.
WilliamTech and RoadHopper like this.
post #3 of 69 (permalink) Old 04-14-2016, 03:47 AM Thread Starter
RoadHopper's Avatar
LOL. Maybe you can. But ima old and slow and careful and have a flight of stairs i need to carry that engine up among all the rest . . .
good exercise and i realize you meant "you" in general for others.
but seriously laughed when i read that. LOL
post #4 of 69 (permalink) Old 04-14-2016, 04:16 AM
Careful with the engine, threw out my back dead lifting it last time.
post #5 of 69 (permalink) Old 04-14-2016, 04:39 AM Thread Starter
RoadHopper's Avatar
My plan is to do an engine "migration" up the stairs. So.. lining up getting a jack from a friend to loan... put some wood on top of it, whatever.. use the jack to support engine close to the bike, by that time the tank will be off, etc.. So with enough top end access, remove the carbs, then the heads, and basically one chunk at a time, strip a handful of parts off the engine until it's as light as can be.
It weighs in at ~150 IIRC. so... can probably knock off 50 pounds if lucky. Lifting 100 pounds is not a big deal even with a slipped disc history for me... but omg... those stairs? I lost some ligaments in that wreck back in my twenties. And this is going to be UP and DOWN and UP and DOWN those stairs over and over for uhm...
yeah right... two hours. . hahahahahahahahaha OMG.... too funny.
post #6 of 69 (permalink) Old 04-14-2016, 10:26 AM
Stripped mine in four with beer,coffee and lunch breaks
RoadHopper and Monnerjr like this.
post #7 of 69 (permalink) Old 04-14-2016, 10:38 AM
Step one, take some high-res pics all around the bike.
What about assembly? Are you carrying it back downstairs in one piece?
Might be better to strap it to a dolly, then you just have to heave one step at a time.
RoadHopper likes this.
post #8 of 69 (permalink) Old 04-14-2016, 11:04 AM
Expendable newbie
evulcannibal's Avatar
Oh, yeah. I also recommend taking pictures before and crap ton during the removal. Especially as you remove parts and bolts, so that you can refer back to them later and install the right pieces in the right location.
Don't trust your yourself to remember all these little details unless you have a photographic memory, in which case I'm jealous.
Also devise a system in which you can neatly organize all the bolts and not just mix them all in a bowl.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #9 of 69 (permalink) Old 04-14-2016, 11:38 AM
ditto on all the above
.......suggest purchased box's of various size zip lock bags - bagging associated nuts/bolts/parts together in groups....
clean as you reassemble
and rags...go to Goodwill on 50% off day....huge assortment of suitable rags for cheap ! (in 2xxl & 3xxxl sizes - - )
You also will need an 18mm x _?__ bolt to pull the flywheel....
post #10 of 69 (permalink) Old 04-14-2016, 11:58 AM
calebj's Avatar
18x1.5mm, also available as Motion Pro 08-0116 for about $9 online.
Ditto to the zip lock bags. Grab a box of the cheap ones from the store and a wide tip permanent marker. The fine point ones try to push into the plastic on the bag too easily.
WilliamTech likes this.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
