new rider 9984's single belt alternator mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 11Likes
post #1 of 37 (permalink) Old 06-03-2015, 08:49 AM Thread Starter
I have finally perfected my single belt alternator mod that eliminates the dreaded and inevitable stator failure and in the long run saves you money and time on fixing a charging problem.
I want to make it clear that i am not faulting Kanuck69's design at all it worked beautifully for him and looks clean on the bike.
My design differs from his in a few ways.
1. I set mine up with one belt instead of two
2. the alternator i used is easily found at the local parts house and is rated at 63 amps max output and sells for around 40 dollars with a lifetime guarantee where as the alternator kanuck69 used i believe was ordered off the internet rated at 30 amps which is enough to do the job but rings up closer to 100 dollars however it is smaller in size and a bit prettier.
3. I used a 3/4 inch output shaft and he used a 1 inch output shaft
I would like to offer my mod up for sale as an alternative to the tuxedo mod.
Yes the tux mod plate is going to be cheaper and does make changing the stator a breeze once the mod has been completed but the down side is you are still going to spend 80 bucks or more every time your stator fails and don't for get that pesky regulator that runs 40 bucks or more for a used mosfet. Then there is the down time while waiting for parts to arrive. Time in which you might be missing a rally and definitely missing a ride. All in all the tux mod only saves you on labor price and labor time.
My alternator mod on the other hand will be a bigger initial investment of course but listen to the benefits. Lets say you are riding down the road one day and and that heavy duty alternator you put on your bike finally calls it quits. What ever shall you do? Well lets see grab your trusty ol' smart fone and find you the nearest parts store (which ever one you originally bought your alternator from) and see if they have another alternator in stock. I am willing to bet they do and if by chance they don't the can usually get one by the end of the day or the next morning at the latest. Here is the best part to remove the alternator you need a 10, 13, and 14 mm wrench thats it 5 mins of work and the alternator is off. another 5 minutes and the new one is installed. No more waiting a week for parts or fighting with pesky seized up phillips head screws on the side cover no need for allen wrenches all that is eliminated. Well now that you have heard the pro's here are the con's.
The bike will no longer look stock and will be about 7 to 10 pounds heavier thats it. Oh don't forget the conversation starter it will be.
I will be asking $275 for the mod and it will include everything needed minus the alternator itself you will buy your own alternator from a local parts store preferably autozone or orielly's or advanced so as to get a good warranty in your own name and like i said above they run about 40 bucks but there is a core charge that you will have to pay unless you have an old alternator laying around to use as a trade in.
I painted mine black to match the bike but customers will receive bare steel parts that you can paint or chrome to your hearts content.
Kanuck69 has a thread on his design as well I am unsure if he is selling a kit or not and if he is I couldn't tell you his asking price but feel free to go with his design if you like it better.
Feel free to contact me by phone to place an order my number is in my signature at the bottom of this post.
Here are the pics of my design mounted on my bike.
post #2 of 37 (permalink) Old 06-03-2015, 08:58 AM Thread Starter
I do not have any kits made at the moment but i will start on one as soon as someone says they want one.
If multiple people want one I can start keeping stock in the kits.
post #3 of 37 (permalink) Old 06-03-2015, 08:37 PM
Interesting project new rider.
I see you have the tour bell riding low to scare all those troublesome gremlins off too, eh?
post #4 of 37 (permalink) Old 06-03-2015, 11:13 PM Thread Starter
thats my american express i never leave home without it
post #5 of 37 (permalink) Old 06-04-2015, 09:31 PM
I do thank you for giving credit for the origin of this. I only hoped it would be improved upon.
since moving to the 900, I don't really have a "big" interest in producing anything as a kit for the 750. Especially since most of it is gone now. =)
my only question I have now seeing the completion (which is great by the way), it looks like the two pulleys are similar in size. Do you have enough rpm's at idle to maximize the alternator? That's why I did a larger drive pulley. To bump up the alternators rpm & have reliable full power all the time.
post #6 of 37 (permalink) Old 06-05-2015, 07:07 AM Thread Starter
you are welcome brother
as far as the alternators rpms go i would go as far to say the alt. is not putting out full potential at idle but it is meant to charge the battery for a 1/2 ton chevy truck so it puts out plenty of juice to give a 12.8 volt reading on the meter at idle and the bearings in the alt are rated for up to 9k rpms
i used pulleys of the same size so i can safely say that the alt is running the same rpm as the bike which idles at 1k rpm
an old 79 chevy 1500 idles at 750 rpm in neutral and around 600 rpm in gear and the alt does a fine job there however i am sure the alt is spinning faster than the crank on the chevy
with the bike at 5k rpm this alt puts out 14.6 volts and enough amps to run the bike at idle or at speed with the battery disconnected i can promise this one too you because i tried it
post #7 of 37 (permalink) Old 06-25-2015, 04:18 PM
Bad ass!.. Nice work!... Can I ask what seat are you running?
The constitution was not written for We The People, but rather for those who SERVE THE PEOPLE!
The strongest reason for the people's right to bear arms is as a last resort to prevent tyranny in government,
T Jefferson.....Don't Tread On Me!
grousehunter1475 is offline
post #8 of 37 (permalink) Old 06-25-2015, 04:33 PM
If my memory serves me correct I think it's a meanstreak seat he has
post #9 of 37 (permalink) Old 06-25-2015, 05:05 PM
Can we get some video of that?
post #10 of 37 (permalink) Old 06-25-2015, 05:30 PM
What of my memory working?
