LED light Project - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 36 (permalink) Old 05-23-2015, 03:55 PM Thread Starter
Dirt to road
duraholiday's Avatar
LED light Project
I started to do this project for my turbo on my truck aways back but then I bought this bike so i decided to try it here first. The goal is to have leds shining down from under the gas tank. The point of the potentiometer is so when the throttle is turned it will adjust the brightness of the lights, so the more i turn the throttle the brighter it will get. The 2 momentary switches are to change the color from yellow to blue and the other is to turn off the potentiometer so the lights remain a constant brightness.
Materials needed:
  • Arduino board
  • proto board
  • 1 led blue strip
  • 1 led yellow strip
  • 2 momentary switches
  • 1 power switch (master switch)
  • 1 Potentiometer
  • 2 frets
  • lots of wire
  • solder
  • outlet box
Proto board
Arduino board
frets
LED strips
Potentiometer
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 36 (permalink) Old 05-23-2015, 03:58 PM Thread Starter
Dirt to road
First,
Ear shave
made my own cutting tool
Finished:
Days running: 0
Up coming Projects:
post #3 of 36 (permalink) Old 05-24-2015, 06:13 PM Thread Starter
Dirt to road
I cut and bent some sheet metal for the lights and fitted it to the bike.
Then I cut and glued lights to the tank
Next trimmed the handle bar end cap so the potentiometer would fit in it, next i soldered and ran the wires through the handle bar and through a hole in the middle of the handle bar.
Next i mounted the switches on the shroud in front of the gas tank
Next step is soldering the lights and running the wires
Days running: 0
Up coming Projects:
post #4 of 36 (permalink) Old 05-27-2015, 01:45 AM Thread Starter
Dirt to road
Update:
Because of my lack of classes today I spent most of it soldering all the led lights together on the center piece and the gas tank....
Here is a picture of the board all soldered together, courtesy of one of my room mates whos a computer engineer, he'll also be writing the program. Couldnt do it to save me life, mechanical engineer problems....
Picture of the blue lights on the center piece
And the amber leds
Tomorrow ill be connecting everything on the bike and my room mate will be writing the program.
Days running: 0
Up coming Projects:
post #5 of 36 (permalink) Old 05-27-2015, 11:13 PM
Sock's Avatar
Out of curiosity, what's the padlock on the gas tank all about?
1991 VN750, purchased 5/5/15, 9092 miles
Sock is offline
post #6 of 36 (permalink) Old 05-28-2015, 09:53 PM
Keeps the chickens inside,silly.ya don't wanna ride down the road and have the chicken get out of the gas tank
post #7 of 36 (permalink) Old 05-29-2015, 03:02 AM Thread Starter
Dirt to road
I was using it as a weight haha for when the glue was drying
Days running: 0
Up coming Projects:
post #8 of 36 (permalink) Old 05-29-2015, 03:04 AM Thread Starter
Dirt to road
Project done!! i have a few bugs to work out in the program but heres the progress! Ill be adding more lights also.... not bright enough for me yet.
Days running: 0
Up coming Projects:
post #9 of 36 (permalink) Old 05-30-2015, 11:03 PM
Kevinf's Avatar
Nice work!
Kevinf is offline
post #10 of 36 (permalink) Old 05-31-2015, 06:34 PM Thread Starter
Dirt to road
Thanks! When i get to working perfectly ill post an update. Im goin to do the same thing for my turbo on my duramax but ill be goin off the boost after the turbo
Days running: 0
Up coming Projects:
