Redoing a buell - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-12-2015, 07:29 PM Thread Starter
Redoing a buell
Just cleaned out the carb which was all gunked up and still can't get it to fire. The battery is garbage. I was using the car to jump it. I sprayed starter fluid into it and it started but quickly died out. What am I missing?
post #2 of 16 (permalink) Old 05-12-2015, 07:33 PM Thread Starter
It's a Buell blast 500cc by the way
post #3 of 16 (permalink) Old 05-12-2015, 08:41 PM
Crowley
crowley1027's Avatar
Could be anything....... Fuel, air, spark, compression
crowley1027 is offline
post #4 of 16 (permalink) Old 05-12-2015, 08:41 PM Thread Starter
Help!! Lol
post #5 of 16 (permalink) Old 05-12-2015, 08:42 PM Thread Starter
Just put new super in it. I only took the carbs about to clean the jets. May take the spark plug out tomorrow. The jets were filthy. Like she ran oil through em lol
post #6 of 16 (permalink) Old 05-12-2015, 08:50 PM
,is any fuel coming outta the petcock
post #7 of 16 (permalink) Old 05-12-2015, 09:18 PM Thread Starter
Didn't think of that. Should I disconnect the line and see.
post #8 of 16 (permalink) Old 05-12-2015, 09:20 PM
Not sure if they are vacuum operated but if it is,fuel should come out when ya crank it over.if it isn't,fuel should just come out.if ya goats fuel check your spark
post #9 of 16 (permalink) Old 05-12-2015, 11:15 PM
Sock's Avatar
Sounds like a fuel delivery issue. If the carbs were funky, it stands to reason the tank might be too. I made a temporary handle bar tank to test things when a tank is off. It's a clear diner style condiment squeeze bottle with the bottom cut off. Hang it with a clamp, a foot or so of hose off the nozzle going to the carb inlet and you have a small gravity fed tank.
1991 VN750, purchased 5/5/15, 9092 miles
Sock is offline
post #10 of 16 (permalink) Old 05-16-2015, 12:33 PM Thread Starter
Took the tank off and PC. Inside mesh of the PC Is prestine. PC flows correctly too. Spark plug is black on the top. Any other ideas fella's?
