Frame mod need 2nd opinion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 04-09-2015, 12:14 PM Thread Starter
So I did this today, wanted to slice the frame in between the two bolts on the front cross frame /bolt mount... And slice inbetween the two center 6mm Allen bolts behind the kickstand...My thinking is that the flat stock I will hold it together with ease I don't plan on sitting on her with the kickstand down (I wouldn't do it even unmodified). But it should hold her up when parked... What do you guys think?
ID:	22529   Click image for larger version
The constitution was not written for We The People, but rather for those who SERVE THE PEOPLE!
The strongest reason for the people's right to bear arms is as a last resort to prevent tyranny in government,
T Jefferson.....Don't Tread On Me!
grousehunter1475 is offline
post #2 of 23 (permalink) Old 04-09-2015, 01:01 PM
Hmmmm....something in the back of my head screams bad idea. Besides the aesthetics.... I can see some things going just out of alignment if you ride over a pot hole or a big bump. You are also transferring more stress to each of those bolts on the engine mount. I dunno man its your bike, just my $.02
post #3 of 23 (permalink) Old 04-09-2015, 01:20 PM
if that was boxed and welded properly, I would think its ok, but as is, I agree with M_angell
post #4 of 23 (permalink) Old 04-09-2015, 01:47 PM
Itīs Your bike ...and life... (dangerous idea IMHO)
FINLAND
Bike "The Painkiller"
MODS:
Custom "DIY" exhaust, 2:1
PODS
New handle bar
Forward controls
Modded seat
Modded frame
Modded front fender
New head light
Mini blinkers
New digital speedo/dash
Keyless (remote controlled)
and lotīs of small mods...
Color: Black and Orange
tzrwesku is offline
post #5 of 23 (permalink) Old 04-09-2015, 01:51 PM
Is that a crack behind the kickstand?
post #6 of 23 (permalink) Old 04-09-2015, 01:53 PM
The reason I'm asking is because my 85 frame turned to Swiss cheese in that area
post #7 of 23 (permalink) Old 04-09-2015, 04:26 PM
JM2001's Avatar
X2, I wouldn't ride it that way.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #8 of 23 (permalink) Old 04-09-2015, 07:53 PM
Mine swayed in snake grooves and didn't like concrete expansion joints.went into a violent headshake at about thirty halfway through a turn and threw me to the ground.I'd be looking for a frame...
post #9 of 23 (permalink) Old 04-09-2015, 10:02 PM
OK, I have to jump in on this one. I did a similar mod to mine several thousand miles ago, probably on my 3rd stator change if I remember right.
I never posted anything about it as I knew it would attract a ton of negativity.
But, I did it a bit different. I had a piece of tight fitting pipe fit into the vertical portion of the frame with bolts running thru it locking that all together. Anyone who has seen my bike never noticed the mod.
The clutch cable clip covered the cut in the frame. The other cut was back on the lower portion of the frame, just behind the oil sight glass. This had an exterior piece of pipe holding it.
Now, unless your as adventurous as I & willing to do multiple stator changes, this should never be necessary. But it is possible & stable. I did about 30,000 miles with my frame this way.
post #10 of 23 (permalink) Old 04-09-2015, 10:12 PM
A tight fitting pipe would keep everything in line way better than flat stock. I've actually seen that done on a few bikes in a few ways. If you can maximize the stability of the area you cut it shouldn't be a problem. The key is considering each and every way that section of frame can move and then try to work against those forces.
