New handlebars, old grips? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 12-02-2014, 05:36 PM Thread Starter
A buddy has a set of bars that I think will look good on my bike. Problem is, I can't figure out how to remove the stock grips without cutting them off. I don't want to buy a new set of grips, so if I can't get them off without killing them it's not worth it.
machineman603 is offline
post #2 of 12 (permalink) Old 12-02-2014, 05:49 PM
cglennon's Avatar
I removed mine using simple rubbing alcohol. Simply peel back the inner edge of the grip from the bar, pour in rubbing alcohol, then gently twist to work it in. Keep repeating to work the alcohol down the length of the grip (about 3 or 4 pours of alcohol). At some point the grip will slide right off. Took about 3 minutes per grip. Wipe off any glue residue, let dry and reattach using hair spray.
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 12 (permalink) Old 12-02-2014, 07:24 PM
Deviate's Avatar
Mineral spirits is what my dad uses when he is replacing golf club grips...that might work too. Also, try using a hair dryer to loosen up any adhesive on there so they can come off a little easier.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #4 of 12 (permalink) Old 12-03-2014, 09:19 AM
You only need to remove the left grip as the right one comes off with the throttle sleeve. The above suggestions work , and a compressed air nozzle can help too...
post #5 of 12 (permalink) Old 12-03-2014, 11:20 AM
I lowered my bike into a vat of olive oil. Conditions the seat too.
post #6 of 12 (permalink) Old 12-03-2014, 11:32 AM
Extra Virgin or Light?
A little balsamic vinegar and some crushed garlic and you got a salad....
post #7 of 12 (permalink) Old 12-03-2014, 12:12 PM
I used WD40. I just peeled it back a bit, shot some in there with the straw thing, and would keep pushing the straw in further until it was all the way in. At that point, the grip came right off. I wiped it down, and it installed fine, and grips fine.
post #8 of 12 (permalink) Old 12-03-2014, 01:50 PM
Extra virgins are hard to come by(literally lol)
post #9 of 12 (permalink) Old 12-03-2014, 01:53 PM
The real problem is squeez'n the oil out of em.
post #10 of 12 (permalink) Old 12-03-2014, 01:54 PM
I just use my tongue and let em drip...
