My forwards... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 06-05-2014, 09:30 AM Thread Starter
My forwards...
I decided to use bits and pieces from all of the designs I have seen and make my own. Here is the main portion. Once I finish the linkage I will post that as well.
I used 1/2" all thread and covered it with 1/2" shark bite pvc which I had to thread on lol. I used 1/4" aluminum for the brackets and levers. To get the spikes at the end I used jb weld and shaped it then sanded. Then sprayed it all except the levers with rubber....like 10 coats.
tat2brad77 is offline
post #2 of 20 (permalink) Old 06-05-2014, 11:36 AM
Wow, nice work
post #3 of 20 (permalink) Old 06-05-2014, 01:16 PM Thread Starter
Thanks! I also sprayed like 8-10 coats of clear on top of the rubber. Just trying to make sure it holds up lol
post #4 of 20 (permalink) Old 06-05-2014, 02:05 PM
Looking cool! Pointy ends on bikes scare me though. I just see bad images of that stuck in a leg somewhere..
post #5 of 20 (permalink) Old 06-05-2014, 02:38 PM Thread Starter
Lol true...but 2 things... There are a LOT of things that could go in your leg when you go down...and the jb weld is just about 3/8" in the end and then to a point. I am pretty sure I could thump it with a screwdriver and it would fall out.
post #6 of 20 (permalink) Old 06-05-2014, 02:42 PM
You're probably right on both counts. It'll look quite aggressive once you have it mounted.
post #7 of 20 (permalink) Old 06-05-2014, 03:09 PM Thread Starter
I am doing my linkage a little different than Wlofie's...I am offsetting it rather than angling the part that goes on the actual brake and shifter splines. I am still trying to decide what to cover the thread I am using for the linkage. I think I am going with black lacrosse tape. It will match my black wrap on my pipes.
post #8 of 20 (permalink) Old 06-05-2014, 03:40 PM
Well the rubber isn't going to hold up but it looks cool. I used that stuff on my drum sticks and maybe you can just freshen it up every now and again.
post #9 of 20 (permalink) Old 06-05-2014, 03:47 PM
Mountain Man
Spots's Avatar
They look good. I'm going with a set from Wolfie, but I think any forwards will help the comfort of this bike majorly.
"You cannot exaggerate about the Marines. They are convinced to the point of arrogance, that they are the most ferocious fighters on earth- and the amusing thing about it is that they are."
1993 VN 750 bobber/bagger mix named "Halfbreed"
Degoated
Turn signals deleted
Center stand deleted
Custom wrapped straight pipes
Ear Shave
NGK Iridium plugs
Mean Streak seat
MCCT conversion
Saddleman saddlebags
Spots is offline
post #10 of 20 (permalink) Old 06-05-2014, 03:51 PM Thread Starter
Yeah that plus I shaved 3" of padding from the over padded seat lol That alone made a huge difference!
