how to totally bypass safety switches - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 34 (permalink) Old 01-19-2014, 12:24 PM
There are some excellent points made here.
To be honest, all of the miles I put on bikes without safety switches, none were electric start.
wmsonta is offline
post #12 of 34 (permalink) Old 01-19-2014, 02:42 PM
ok, another option to bypass switches (and associated relays in JB)
https://www.vn750.com/forum/showthrea...t=41530&page=2
last post.
michiganteddybear is offline
post #13 of 34 (permalink) Old 01-19-2014, 04:12 PM Thread Starter
last post.
this is a second option that would work however when doing it this way you are bypassing the starter relay not the safety switches
i personally would like to keep the relay in play so if there is ever a fault in the starting system the relay will be able to stop power to the starter and not damage the engine
post #14 of 34 (permalink) Old 01-19-2014, 05:24 PM
Agreed, my method does bypass the relay in the JB. the solenoid is still in play. and remember that if either the ignition or the run/stop is off, the solenoid will not be able to get any power, regardless of what happens in the JB or other circuits.
if you have a solenoid stick shut, thats about the only way to keep the starter runnning when you dont want it, and that can happen no matter what method you use to bypass the switches.
post #15 of 34 (permalink) Old 01-19-2014, 06:38 PM
The post IMO is fine with the disclaimer and warning....personally, Ive never even owned a bike with "safety" stuff...my 85 is my newest....
Just wondering, since its a bit radical and may hurt/confuse noobs, if it should go into the Mods/Builds section....
For safety sake, for idiots, Im gonna move it there....hope ya dont mind Trey.....
post #16 of 34 (permalink) Old 01-19-2014, 09:24 PM Thread Starter
hey your the boss
post #17 of 34 (permalink) Old 01-20-2014, 04:19 PM
well i gotta say a big thankyou for this. As for saftey worries my thoughts are basically if you cant take responsibility for yourself you shouldnt be on a bike. keep up the good work with the tips
paulbute is offline
post #18 of 34 (permalink) Old 01-23-2014, 08:40 PM
Aint no different than runnin a 53 Chevy...it didnt have all the crap either....lol
post #19 of 34 (permalink) Old 01-24-2014, 02:30 AM
Ndr
Once I finish bypassing the safety switch relay, the only thing I'll have left functional in the JB is the fan relay and the fuses. minus the Auxiliary fuse since I deleted those wires as well.
No sure yet how to bypass that relay and still leave the fan fully functional, or if it's even possible/worth it.
Ndr is offline
post #20 of 34 (permalink) Old 01-24-2014, 03:35 AM
Wire the Positive Side of the fan motor to the battery, and the negative side to the Fan Temp switch. Only problem with doing this is that you tae the chance of burning up the fan switch. Another and better way would be to get an automotive type relay and wire it up so that the fan switch triggers the relay to close, sending power from the battery to the fan motor.
