Eliminating Dash and Gauges - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 09-07-2013, 01:28 AM Thread Starter
Young Rider-Young Daddy
Lightbulb Eliminating Dash and Gauges
Hi guys! So I like the bike so far, but one the that stands out is the side by side speedo and tach gauges and the UGLY center dash piece (the piece with the signal, lights, and neutral info)
Anyway... I'm thinking it'd look good (as I am a minimalist) to remove the speedo, tach, and center piece and replace it with a single aftermarket speedo similar in size and shape to the origional. It'd clip on to the handle bars near the center preferably.
Anyone have ideas/pics where the stock gauges and dash are removed?
-YGR
Young Gun Rider is offline
post #2 of 13 (permalink) Old 09-07-2013, 04:06 AM
Ceal's Avatar
Take off the headlight and headlight bucket and work your way from there. It's not hard to do.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #3 of 13 (permalink) Old 09-07-2013, 04:30 AM
Here is a Acewell Didgital Dash 2853 installed on a vulcan 750. The Guage is tthe same size as the Stock Speedo or Tac, but incorperates the whole dash into one unit.
post #4 of 13 (permalink) Old 09-07-2013, 07:40 AM
Deviate's Avatar
In my opinion removing the gauges and dash and replacing with something like the Acewell isn't the problem. It's how ugly everything is under there once you take it all off. I'd like a single gauge too, but I can't figure out a any way to clean up the ugly without a lot of work, time, and money.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #5 of 13 (permalink) Old 09-07-2013, 10:03 AM
R/R = Relocated Redneck
Jakzen's Avatar
You can make a dash panel and put it in to hide the ugly if you're running a windshield or fairing, otherwise, you're right...
I'd like to do something like this, but the wife seems to be out of patience with my tinkering on it for the last several months...
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #6 of 13 (permalink) Old 04-21-2014, 04:14 PM
I've just done this.
It was pretty easy. There are two bolts on either the side of the indicator light box that holds the whole assembly together. I think its a 12mm. Anyway unbolt it and remove it. You will have to disconnect the wiring harness from inside the headlight housing. The headlight can be removed by unscrewing two screws at the 4 and 8 o'clock position. Be sure mark your ignition switch for the "on" position since the position markings are part of the box you're removing.
As you disconnect the wires, turn the bike on and make sure your headlight is still working. I don't think there would be a problem but it's always best to check. If all is well, you can either trace the wires you aren't using and disconnect them further, or if you are feeling froggy, cut them. I traced them to junction just above the coil on the left side and cut them there.
I also removed my left side switch housing, choke lever and clutch switch. If you want to know how to do that, hit me up.
DT
TheDTShow is offline
post #7 of 13 (permalink) Old 04-21-2014, 04:16 PM
I plan to take a grinder to the top triple tree and tidy it up. It still won't be amazing, but it'll be much less clunky looking. I won't grind too much off, just the bolt holes and try to smooth things out. I don't want to risk screwing up its strength.
post #8 of 13 (permalink) Old 04-21-2014, 08:01 PM
I prefer more information. I want gauges for damn everything. Temp of my arse on the seat if possible.
post #9 of 13 (permalink) Old 04-21-2014, 11:47 PM
Goofy, check out that acewel I linked... It has more gizmos than the stock instrument cluster
post #10 of 13 (permalink) Old 04-22-2014, 02:43 AM
Ndr
The only thing that's missing from acewell is a temperature gauge. As far a I was able to find, they do not have an option for one. That would be another gauge you'd have to mount if you want to have that info.
Ndr is offline
