Well did it - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 43 (permalink) Old 09-06-2013, 10:23 PM Thread Starter
Question Well did it
Pimped it
post #2 of 43 (permalink) Old 09-06-2013, 11:17 PM
Mod
Birdhunter02's Avatar
Nice.............
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #3 of 43 (permalink) Old 09-06-2013, 11:25 PM
Nice ,but remember ,pimpin' ain't easy
post #4 of 43 (permalink) Old 09-07-2013, 06:32 AM Thread Starter
Girlfriend said this was all the pimpin i was allowed to do.
post #5 of 43 (permalink) Old 09-07-2013, 03:14 PM
looks nice try running some more red led strips on the bottom of the frame rail i have the big leds on mine and cars definately see me at night
post #6 of 43 (permalink) Old 09-07-2013, 03:22 PM
So are you guys hooking up an ON/OFF switch or running these all the time? I want to eventually get a Blue set for my 900.
post #7 of 43 (permalink) Old 09-07-2013, 03:51 PM
I have mine done up in blue. I used a key fob switch so I can turn them on and off from a distance. Definitely looks slick.
post #8 of 43 (permalink) Old 09-07-2013, 05:29 PM
'03 VN750 "Rosie"
bstew7890's Avatar
I bought mine with lights installed on the bottom of the frame rails and a switch on the neck. They lit up the road under me but that was it. so I moved them to the bottom of the tank but I can't find a good location on the left side. I tried flexing the carb boot but I was afraid that it would wear a hole in it over time. Moved it forward to just above the ear but I'm not happy with that either. Do you have a picture of the left side?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
Last edited by bstew7890; 09-07-2013 at 05:33 PM. Reason: Adding line about a switch
bstew7890 is offline
post #9 of 43 (permalink) Old 09-07-2013, 10:15 PM
Mine are just under tank right now....I drilled a hole in the right side cover an installed a pushbutton switch....I wanna run lights, one strip each, under each fender.....
I did blue on mine because used to have a blue theme....may go red now...
http://imgbox.com/abw9X0AY
post #10 of 43 (permalink) Old 09-08-2013, 06:44 AM Thread Starter
I was surprised these strips stayed on. Im sure they won't last. Plus to take off the tank i now have to remove the wires from the headlight since i have it tied to the same place as the voltmeter. Where is the switched accessories panel spot?
