VN900 Seat Mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-15-2013, 07:09 PM Thread Starter
VN900 Seat Mod
After picking up a VN900 seat in the fall, I finally got around to getting it mounted. I figured that with the back wheel already off (getting a new tire mounted), I might as well dive in.
Prior to mounting the seat, I removed the stock side rails. Using the old and "not shiny" set from my older 86 parts bike, I used a band saw and cut off the vertical part, leaving just a nicely curved rail. This allowed me to continue using the F&S saddlebag supports and relocation brackets.
For mounting the new seat, I basically started by setting the seat on the bike, and then working my way back from the front, supporting and attaching it along the way. It wasn't that hard (mostly because of all the tips and tricks I picked up courtesy of the fine folks here on the forums).
Pictures are here: https://www.vn750.com/forum/album.php?albumid=737
At the front, I grabbed a strip of flat metal, bent it, and attached it to the frame above the existing mount. The height was right, but there was some side-to-side play. I marked the edges of the VN900 tongue, then added bolts with extra nuts. Perfect fit!!
Behind the battery, I built up the frame cross member with some PVC pipe. The first layer is just a 1" pipe with a small strip removed. Then, two smaller pieces (one for each end) with a larger strip removed. I heated these pieces with paint stripper to make them easier to spread and "snap" on. Finally, two pieces of 1.5" pipe to finish it off. Some pipe solvent to "glue" the pieces together, then a tie wrap (just in case).
Above the rear fender I marked where the rear supports are, then attached a simple 1/2" tube to the frame.
To hold the seat down, I was able to insert a bolt into one of the holes in the seat (with a short "T" strap to keep it from falling out), then secured it with a washer and nut. Then, the bolt goes down through the hole in the frame, and a washer and nut secure the seat to the frame from the bottom. I had to cut a hole in the fender to install the nut. The bolt doesn't protrude through the fender into the wheel well.
Next winter, I'll take everything apart, paint the new pieces, and sand and polish the cut-up side rails.
I'm also looking for a passenger backrest/luggage rack ... I hear that something from a Honda 1100 should fit !!
#1 - 1986 Vulcan 750
Purchased Jan of 2012 w/ 41,000 kms
On the road as of April 4
Unfortunately, after third ride (300 km) ... horrible engine noises ...
XXXXX FOUND METAL IN OIL SCREEN XXXXX
#2 - 1993 Vulcan 750
Purchased May 4, 2012 w/55,000 kms
On the road in only 4 days with no major work required
Have moved most of the accessories from #1 to #2
SnakeMurphy is offline
post #2 of 7 (permalink) Old 04-16-2013, 02:27 AM
sparkingdogg's Avatar
how does it feel, compared to the stock seat? looks comfy! nice job on the mod, looks really good. looks to have more "wiggle and slide back" room.
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #3 of 7 (permalink) Old 04-16-2013, 08:51 AM Thread Starter
Feels pretty good so far (only 5 kms to work so haven't really tested it yet). Big bonus is the extra space for a passenger. Even though my gf has her own bike (ZN750) she still like to ride behind me once in a while.
post #4 of 7 (permalink) Old 04-17-2013, 03:09 PM
sweet
post #5 of 7 (permalink) Old 04-17-2013, 10:54 PM
Chuck A.'s Avatar
Glad to see you put the extra supports under the seat. Most people don't but I think it makes a big differents.
Chuck A. is offline
post #6 of 7 (permalink) Old 08-07-2013, 10:17 PM
Which VN900 seat
Hi,
Which seat did you fit, was it a custom job or a stock seat VN900 B (Basic) or C (Custom) or D (Touring).
If it was stock how comfortable have you found it compared to the Vn750 stock seat in particular shock absorbsion !!!! I own a VN7050 Hard tail trike so I think you can understand my shock enquiry!!!!
Cheers, Barry, Plymouth,UK
BEN1400 is offline
post #7 of 7 (permalink) Old 08-20-2013, 09:31 PM Thread Starter
It was just a basic stock VN900 seat. I don't think it had any miles on it at all and I'm still trying to "break it in".
It definitely changed the seating position (upwards a bit) as I had to adjust my windshield.
Unfortunately, although it fits nicely, it's not very soft yet. Even with my "Airhawk" pad on it, I'm sore after a couple of hours. For the short drives, no problems. I'm going to try putting a bit more air in my Airhawk to see if it helps.
