Project Hell Scream - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 138 (permalink) Old 10-03-2012, 01:52 PM Thread Starter
Talking Project Hell Scream
post #2 of 138 (permalink) Old 10-03-2012, 04:16 PM
wrench
Yamamoto's Avatar
Good luck, take lots of pictures with the progres you make.
Yamamoto is offline
post #3 of 138 (permalink) Old 10-03-2012, 07:26 PM
dude when did you name your bike black betty cause thats the name of my 86
why you gotta be stealing my stuff man and then you gotta go all out and make it look better than mine
just kidding around but be sure to post up millions of pics
post #4 of 138 (permalink) Old 10-03-2012, 10:22 PM
no your bike will never be better than mine cause your bike will never be mine lol but im sure its gonna be better looking
post #5 of 138 (permalink) Old 10-05-2012, 12:58 AM
ok so periodically your bike is better i cant get out of first gear somethin broke in the shift linkage or the rod its self
post #6 of 138 (permalink) Old 10-05-2012, 02:22 AM
how about black sunshine
this motor only has 13k on it
post #7 of 138 (permalink) Old 10-05-2012, 11:24 AM
Okiebezer's Avatar
Here's the kanji for your phrase
黒龍王は、魂を燃やす
Okiebezer is offline
post #8 of 138 (permalink) Old 10-05-2012, 01:59 PM
my sister put a vinyl hatchet man on her car and its just primer but it stuck fine just dont peel it off cause it will take the paint with it
or you can use my method paint the whole peice the color you want the graphics to be then stick the the decal on and flat black over it then remove the decal if you look hard enough you can find a clear that is a matt finish so you can seal the paint without having the shine of gloss
post #9 of 138 (permalink) Old 10-09-2012, 04:00 PM
did they come with a little plastic spacer?
cause they did the same thing to me but instead of returning them i just wrapped a layer or two of black tape around the clutch side no glue needed and used the spacer to take up the slack in the throttle side if that is the case for you you're going to need to shave the inside of the kill switch housing down some so the throttle wont stick
post #10 of 138 (permalink) Old 10-10-2012, 08:26 PM
I would wet sand the side covers starting with 120 grit and working up to 1000 grit, primer the covers with sandable primer and resand with a green scotch pad just enough to take he sheen off, then paint them flat black
