More Gas (How I made a tank bigger - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 78 (permalink) Old 02-21-2011, 09:51 PM Thread Starter
Hoser
junkyardroad's Avatar
Bought a used tank on Ebay.
Here's why it was cheap.
The welds have been ground and all the seams are LEADED. I have a dual outlet Pingle but the weld bung is backordered. I'll post more when that is done.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #2 of 78 (permalink) Old 02-21-2011, 10:04 PM
Interesting approach jyr.
I`ll be curious to see how much more fuel it will hold. I expect about a gallon maybe??
post #3 of 78 (permalink) Old 02-21-2011, 11:59 PM
Ceal's Avatar
What equipment did you use? To cut and weld and stuff...
Ceal is offline
post #4 of 78 (permalink) Old 02-22-2011, 12:57 AM
With nice cuts as those.. it looks like he used a die grinder to make the cuts.. and a regular mig to weld it up.. an angle grinder to grind own the welds, then he used lead to fill in the pinholes left by welding
post #5 of 78 (permalink) Old 02-22-2011, 07:53 AM
n2omike's Avatar
Nice! These tanks are really thin compared some of what else is out there... which definitely doesn't make the job any easier!
I guess you plan to seal it like you would a rusted tank, when you're done?
Good Luck!
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
post #6 of 78 (permalink) Old 02-22-2011, 09:37 AM
You will have some prospects with this done & fitted. I'm pretty sure there's some money to be made here! More Gas, Awsome! So many want a bigger tank.
Oh Yeah, Great Job So Far.
post #7 of 78 (permalink) Old 02-22-2011, 01:28 PM
Ceal's Avatar
How do you use lead to fill in the holes in the welds? Just heat it up and apply it? Lead electrode? Lead wire?
I'm asking cause a friend had a leaking tank, he took it to a lot of people and no one seemed to be able to seal it. They kept trying to weld it and they never got it to stop leaking. I suppose they have no idea how to use lead for this over here, so it might be good to know how it's used so at least I can tell them if I ever need it.
Ceal is offline
post #8 of 78 (permalink) Old 02-22-2011, 03:08 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Since the project is not done and on the bike, you don't yet know how this will affect your turning. The handlebars come really close to the tank in factory condition, this will mean the bars will contact the sides, I'd imagine.
I wonder if making the tank taller would have been a better way. The center of gravity might be affected going the tall route but you can't have everything.
Any real effort to increase fuel capacity deserves a definite applause to the tinkerer.
Many people are waiting to see how this turns out since lack of range affects us all.
Chris and Shim is offline
post #9 of 78 (permalink) Old 02-22-2011, 03:20 PM
I`m not a bodyman, nor have I ever seen lead used, but before light weight fiberglass body filler was available, lead was used (and often overused) for autobody repair. I imagine it is applied somewhat like solder, but using the lead in bar form. Hopefully someone experienced in it`s use can elaborate on the process.
post #10 of 78 (permalink) Old 02-22-2011, 03:50 PM
flitecontrol's Avatar
Use this, it works: http://www.caswellplating.com/aids/epoxygas.htm
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
