Pulling Engine to replace head gasket - Page 4 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #31 of 34 (permalink) Old 02-08-2020, 01:59 PM Thread Starter
Jason Pittenger's Avatar
Removing old gaskets sucks!
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #32 of 34 (permalink) Old 02-08-2020, 02:10 PM
Thinking someone ran premium gas judging by the carbon, if it wasn't burning oil.
post #33 of 34 (permalink) Old 02-09-2020, 12:47 AM
When I pulled the engine out of mine to replace the stator, I left the front bevel gearcase in place. I had it off a couple years before, and found it very difficult to install with the engine and final drive in place. You have to line it up with the driveshaft AND the engine, and there is a spring between it and the engine that makes it hard to hold in place while putting the bolts in. I went through three gaskets (which are very thin and easily damaged) before finally getting it. But when I pulled the engine, I practically had the entire bike apart, including the rear wheel and final drive. I did have to remove the radiator and front exhaust manifold, but I was able to turn it enough, with about 1/16" to spare, to get the engine out. I took it completely out to give me plenty of room to work on it. I'd much rather do a lot of easy but time consuming disassembly than having to deal with the frustration of fighting with things where you really don't have enough access to it.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #34 of 34 (permalink) Old 02-15-2020, 04:51 PM Thread Starter
Did I mention how much I hate old gaskets? I bought a drill attachment to grind away the old gaskets carefully. Its slow going, even with a power tool. AND I have to make sure not to take any aluminum away.
