Motorcycle jack - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Goofyfoot2001
post #1 of 6 (permalink) Old 09-19-2018, 06:13 PM Thread Starter
I'm a rider
One1's Avatar
Motorcycle jack
I'm not pleased with where this jack sits. Barely on the back engine, or scooted forward on the starter. I'm going to get some blocks and build up the sides to the frame. Issue on the VN is the exhaust hangs below the frame and the motor is even lower.
I know there is no way to do it without blocks, just wanna see if anyone has a pic of their setup to compare to. I'll be using the tie downs on the jack, but still don't like those slippery blocks being there.
Clickable thumbs:
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is online now
post #2 of 6 (permalink) Old 09-25-2018, 05:42 PM Thread Starter
I'm a rider
One1's Avatar
As you guys know I do not do half ass Solutions so I decided that I would do this for anyone else that has a motorcycle jack and needs a template. if you do it like this it will fit the frame perfectly
ID:	45161   Click image for larger version
ID:	45163   Click image for larger version
ID:	45165   Click image for larger version
ID:	45167   Click image for larger version
1981 KZ750
One1 is online now
post #3 of 6 (permalink) Old 09-26-2018, 10:49 AM
ubertalldude's Avatar
Nicely done as always. I've never lifted the motorcycle with a jack like that, but I did use that same jack to remove the engine. Even then, not an ideal situation, but it got the job done.
ubertalldude is offline
post #4 of 6 (permalink) Old 09-26-2018, 03:50 PM
I never used a jack on my VN because I could do everything with the centerstand. On my sporty I would use straps to attach it to the stand and jack it up to tighten the straps.
ubertalldude likes this.
post #5 of 6 (permalink) Old 09-26-2018, 04:00 PM Thread Starter
I'm a rider
One1's Avatar
I like the center stand of the VN it's awesome. When i do the front shocks, bearings, etc and need the front to go up and let the wheel off the jack is a nice addition.
1981 KZ750
One1 is online now
post #6 of 6 (permalink) Old 12-03-2018, 08:50 PM
SkyPilot's Avatar
I prefer to work on a propper shop lift.
Wood blocks and a flat jack suffice with the front wheel clamped and strapped.
Never liked the balancing act required with those backbreaking cradle jacks...
But most floor work (like working on the front end, or changing a tire) can be accomplished by simply triangulating the kickstand, one wheel and a floor jack.
SkyPilot is offline
