Evaporative systems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By ubertalldude
post #1 of 3 (permalink) Old 06-14-2018, 03:07 PM Thread Starter
Evaporative systems
I live in Utah and our state doesn't require smog items. Can I remove all the evaporative without affecting the running of my bike?
Danoman is offline
post #2 of 3 (permalink) Old 06-14-2018, 04:14 PM
ubertalldude's Avatar
Yes, look up the "earshave" procedure on this website for a full explanation of how to remove the emissions gear. (NOTE: you probably do NOT need to re-jet as is indicated in the "main" writeup. #42 pilot and #142 main is WAY too rich)
roadpouring likes this.
ubertalldude is offline
post #3 of 3 (permalink) Old 06-14-2018, 08:05 PM
If you mean the charcoal canister for Calif emissions, you can lose it and cap off any vacuum lines, if any. I haven't actually seen one, but the Calif. bikes have them. Just be sure you keep the gas tank vented.
Otherwise, it's as uber said for the airbox.
Coaster, is the term used here for the plate to cover the reed boxes, or those can just be plugged or capped.
