Picking gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Motorcycle Safety Discuss safety ideas/tactics or safety-related products.
Ride Smart!
post #1 of 6 (permalink) Old 07-22-2014, 08:01 AM Thread Starter
Picking gear
Copied from another forum. As we been getting some new members who are also new riders, thought this might be useful to them:
Abrasion Resistance.....
Been some questions about what kind of gear to buy. Found this awhile back and thought might be good to post up again.
Tear and Abrasion Strength by the numbers
Pounds of force until fabric tears Abrasion cycles on pavement until fabric fails
CottonJeans 4.5 pounds to tear 50 cycles to failure
70 Denier Standard Nylon 4.5 pounds to tear 165 cycles to failure
500 Denier Polyester 8 pounds to tear 180 cycles to failure
200 Denier Standard Nylon 7.5 pounds to tear 275 cycles to failure
500 Denier Cordura 22 pounds to tear 710 cycles to failure
620 Denier Cordura 35 pounds to tear 1200 cycles to failure
NEW Competition Grade Leather 80-110 pounds to tear 1200-1700 cycles to failure
1000 Denier Cordura 110 pounds to tear 1780 cycles to failure
Air Mesh Kevlar 1260 pounds to tear 970 cycles to failure Stretch Kevlar Blend 420lbs pounds to tear 1800 cycles to failure
This is how quickly some materials take to hole:
Material Seconds
Denim 0.2 to 0.5
Some race gloves 0.6
Most leather gloves 1.0 to 1.8
Keprotec stretch material 0.9
Poor Kevlar 1.0
Two layers of waxed cotton 1.3
1.3mm thick cow hide 3.8
Two layers of 1.3mm thick cowhide 18
Three layers of 1.3mm thick cowhide 55
Two layers of Kevlar plain weave 5.6
Suede 18
Boot leather (generally 2.2mm thick) 20
Leather stretch panels 20.4
There is also this test from a while back:
Drag Test
"For the Drag Test, samples were stitched to a bag that held a 75-pound
sandbag inside a milk crate, then dragged behind a pickup truck..."
New, 100% Cotton Denim Jeans ----------------------- 3' 10"
Senior Balistic Nylon ----------------------------------- 3' 10"
Leather, Lightweight, Nude Finish, 2.25 oz/sq. ft. --- 4' 3"
Leather, Fashion Weight, 1.75 oz/sq ft. ------------- 4' 4"
Two-year-old 100% Cotton Denim Jeans ------------ 4' 5"
Cordura Nylon Type 440 ----------------------------- 18' 3"
Kevlar 29 Aramid Fiber, Style 713 ------------------ 22' 1"
Leather, Competition Weight, 3 oz/sq. ft. -------- 86' 0"
Taber Test
"For the Taber Test, the specimen was mounted on a rotating platform and
scuffed by two rubber-emery grinding wheels." The numbers represent the
number of revolutions until the fabric totally fails. A vacuum clears
debris.
Two-year-old 100% Cotton Denim Jeans 168
New 100% Cotton Denim Jeans 225
Kevlar 29 Aramid Fiber, Style 713 506
Cordura Nylon, Type 440 559
Leather, Lightweight, Nude Finish, 2.25 oz./sq. ft. 564
Leather, Fashion Weight, 1.75 oz./sq. ft. 750
Senior Ballistic Nylon 817
Leather, Competition Weight, 3 oz./sq. ft. 2600
More to consider...
"Finally, protection from road abrasion cannot be guaranteed by a
materials abrasion resistance alone. A jacket may have panels of
highly abrasion-resistant materials, yet if low-quality stitching joins
those panels and the seams come apart upon impact or during a slide, then
the abrasion resistance of the panels could count for nothing.
Furthermore, an ill-fitting garment may ride up in a slide, contorting
the body and exposing the skin. And the best jacket in the world, left
unzipped and/or unsnapped, won't give riders the protection they pay
for. When it comes to safety, the issues are more complex than just the
abrasion resistance of materials." __________________
From another site:
The textiles vs leathers debate is all about tradeoffs. Choosing which material to use to cover your hide with and spend your pennies on depends on how much you value individual tradeoffs and ultimately, your intended use and riding conditions. Sounds easy enough, but deciding between textiles vs leathers has had great rider minds in a muddle and increasingly so over the last couple of years as the quality and versatility of both materials has improved so much! Just type in “textiles vs leathers ” into google and you will find that 90% of the results are from forums with the answer ultimately resulting in the fact that it depends on your personal preferences. The problem is that this does not help those new to the biking world who have not had the time or experience to develop their own, well-guided preferences… and so the argument goes on.
But, it’s really quite simple if you use the BMI (Best Motorcycle Information) textiles vs leathers test. This test takes the four most differentiating attributes of the two materials into consideration – price, maintenance, comfort and protection. Each attribute is also assigned to either leathers or textiles, depending on which material has the greater advantage in terms of the attribute. After reading the brief summary on each, assign a score out of a hundred to each attribute, giving those attributes that are most important to you higher scores, so that in the end the total score of your four attributes adds to 100. Then add up the score that you gave to the leather attributes and textile attributes, and the material with the highest score is your answer – and best of all it will be unique to your personal preferences.
Price - Textiles
Motorcycle textiles are cheaper to buy than leathers. It is also much harder to judge the quality of leathers and so you take the risk of paying a lot of money for a suit that does not have quality stitching and construction. (Just beware however that it is widely accepted that your textile suit will probably only survive one crash before you have to fork out for a new pair.)
Maintenance - Textiles
This one is simple – motorcycle textiles can be thrown in a commercial washer, while leathers will need to be sent to the cleaners.
Comfort - Textiles
Motorcycle textiles have an all weather capability: vents for when it is warm, liners for when it is cold and water resistance for rain. It breathes more easily than leather, and water slides off it like a ducks back.
Leather is also much heavier than textile.
Protection - Leather
Tests are conducted all the time to compare the abrasion resistance of motorcycle riding gear materials and leather always comes out on top as the most durable material. Furthermore, leather does not melt from friction, it will cushion your fall more than motorcycle textiles would and it offers the best protection against a road rash. The fact that leather also lasts through multiple crashes whilst textiles will probably only last through one, says a lot about the difference in protection and impact between the two materials.
The textiles vs leathers debate basically comes down to protection vs everything else.
__________________
post #2 of 6 (permalink) Old 07-22-2014, 08:08 AM
See now that just scares me. I hate leather so will be sticking with my all season textile with some armor in it.
post #3 of 6 (permalink) Old 07-22-2014, 10:37 AM
Knifemaker: Copied from another forum. As we been getting some new members who are also new riders, thought this might be useful to them:
Informative...Great Post!
post #4 of 6 (permalink) Old 07-22-2014, 11:14 AM
GloryRider's Avatar
Now we just need to figure out a way to cool the leathers down in the summer!
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #5 of 6 (permalink) Old 07-22-2014, 12:44 PM Thread Starter
Well one useful solution I've seen are the "composite" jackets that are part leather and part Cordura. I think Tourmaster makes one and a few other makers do. Having leather on the arms back and shoulders with textile in between.
However, from actual crash reports I've seen, the better made textiles do a pretty good job protection wise in most cases. Full leathers seem more suited to a track where you might find your self sliding from a triple digit mishap.
Most street accidents occur at slower speeds where the limits of textile or Kevlar gear aren't pushed.
I love my mesh jacket...I only wear my leather when it's cool enough out.
post #6 of 6 (permalink) Old 07-22-2014, 03:48 PM
Senior Lurker
Sloppyburpfest's Avatar
Hmm, they left out the abrasion tests for egos.
Like the old biker rabbis used to say: You're better off wearing a yarmulke than the $10 helmet, at least you'll have your faith to protect you!
Ride safe, -Sloppy
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
