Lightening Storms - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Motorcycle Safety Discuss safety ideas/tactics or safety-related products.
Ride Smart!
post #1 of 15 (permalink) Old 06-29-2010, 08:54 AM Thread Starter
Lightening Storms
Just a quick heads up on something I overlooked. We get aggressive and productive lightening storms around here. They're great because they cut the 100 percent humidity to about 85 percent. They're also great because they equalize all that atmospheric pressure which brings several beautiful days to follow - like today.
The one thing I overlooked: debris in the road. If you're takin' a ride after an electrical storm, give ground crews maybe an extra day to clear road debris. The ride into work today looked post-apocalyptic. Thankfully the roads were clear cause nothin' else was.
Just a heads up.
LibertyPilot is offline
post #2 of 15 (permalink) Old 06-29-2010, 10:30 AM
GIMPYRDR's Avatar
Down here lightening does get bad. However, most of our debris is from wind damage.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #3 of 15 (permalink) Old 06-29-2010, 12:37 PM
93VN750's Avatar
You kidding, I live in Tampa, the lightning capital of the country. We get a storm several times a week. Companies that build surge/lighting protection equipment build their headquarters here.
But for those not used to these storms, you shed good advise.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 15 (permalink) Old 06-29-2010, 08:43 PM
And do not wear a carbon fiber helmet durring the storm.
post #5 of 15 (permalink) Old 07-18-2010, 01:09 PM
Fire Ant's Avatar
A couple of months ago, I was caught at work on the bike with a big cluster of storms moving in (that, according to NOAA, weren't predicted to be there earlier in the day), a small gap, and then a big cluster moving in behind the first one. I tried to time it so that I would "shoot the gap" between the two big globs of storms. Unfortunately, when I got about halfway home, I realized that the first glob had suddenly parked itself directly between me and home and wasn't moving. I stopped underneath a carport at a church to wait it out. People from the church kept walking past me and asking me if I had some aversion to riding in the rain. I told them that no, I didn't have an issue with the rain (I had my raingear on), but that I did wish to put off being electrocuted for as long as possible...
I think that I sat under that carport for two hours before the storm died down enough that I felt reasonably comfortable continuing the trek...
--FA
K.J. "Fire Ant" Lord
VROC #28807
Decatur, TX
'03 VN750 "Serenity"
Rear Turn Signal Relocation
Front Brake Replacement
Spline lube, per Fergy's excellent instructions (that he has posted around here somewhere)
Kevlar Clutch Plates
Metzeler ME880 Tires
Stebel Nautilus Air Horn
ACCTs Rebuilt
Saddlemen Explorer Seat
MCCTs Installed
Kuryakyn Wide Levers Installed
Fire Ant is offline
post #6 of 15 (permalink) Old 07-19-2010, 09:42 AM
bgb708's Avatar
Ahhhh nothing better than getting caught in a storm that was not predicted. And of course, you leave your rain gear at home...
Speed only kills when it suddenly stops.
De-goated
R/R Relocated
Lubed splines
StreetShield EX
bgb708 is offline
post #7 of 15 (permalink) Old 07-19-2010, 02:54 PM
Vintage bike addict
antiq's Avatar
More often than not. That's me. I've never actually worn my rain gear.
Eleanor Roosevelt.
antiq is offline
post #8 of 15 (permalink) Old 07-19-2010, 09:18 PM
Concert connoisseur
wib714's Avatar
screw that, rain hurts!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 15 (permalink) Old 09-21-2010, 01:09 PM
Post Recent lightning fatalities around Hampton Roads
May 2005 - Richard Moran Jr., 43, of Virginia Beach, killed in Southampton County while riding his motorcycle.
Jul 2008 - Tephanie Dawn Kirpes, 23, of Woodbridge, Killed in Sandbridge while Jogging on the beach.
July 2004 - Raul Vargas Arroyo, killed while working on the roof of a Virginia Beach school.
August 2002 - Heather Hewitt, 26, of Chesapeake, killed in a parking lot in Hatteras, N.C.
August 2001 - Lonnie West, 39, of Gloucester County, killed on a boat at a marina in Norfolk.
July 2000 - Brian Okuley, 46, of Chesapeake, killed while doing yard work at a Virginia Beach home.
July 1997 - Waldo Morales, 18, of Nags Head, N.C., killed while sitting on the beach near the Cape Hatteras Lighthouse.
Safety tips
- Lightning can strike as far as 10 miles ahead of a storm.
- Use the 30/30 rule: If the time between the lightning flash and thunder clap is 30 seconds or less, move indoors or into a vehicle. Wait at least 30 minutes after the last clap before going back outdoors.
- Avoid water, metal, or tall and lone trees it is better to crouch on open ground.
w4nmh is offline
post #10 of 15 (permalink) Old 09-21-2010, 01:38 PM Thread Starter
Can we talk about these 2 for just a second? Just.....why? You can't need roof work that bad. You also can't need to take a run that bad!!!
Check this out:
http://www.youtube.com/watch?v=kLJ6oqToKrc
If I have my choice between far from that and possibly getting hit, I'm taking the former. Every. Freekin. Time.
